My design L20D IRS2092+IRFI4020H 200W8R - Page 76 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 18th September 2013, 10:58 AM   #751
vdij is offline vdij  Moldova
I will try if it works. How to attach a file?
Old 18th September 2013, 02:13 PM   #752
please
Old 19th September 2013, 12:40 AM   #753
exflaco is offline exflaco  Armenia
Thanks vdij good work
Old 19th September 2013, 12:52 AM   #754
nigelwright7557's Avatar
Originally Posted by Stammheim View Post
I had a look at the document and yes, that's the ~ +-5,4V behind the resistor. So the IRS is fed by the +-5,4V I already told. But as I have found nowhere I need to know, which voltage range the IRS can be powered, and if I implement an own power supply for the IRS, which voltage I have to put in. Of course I could go the easy way and also limit the voltage to the 5,4V, but because I would go with a 2x6V (or 2x7V) transformer it's important to know, if I have to use some voltage regulators to limit voltage.
Many thanks,
Stammheim
There is an internal zener that limits the voltage to around 7 volts.
To be safe I wouldnt go above +/- 5 volts.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 19th September 2013, 07:56 AM   #755
exactly
Old 19th September 2013, 08:01 AM   #756
Thanks, I'll try this out. Do you also know the ampere-consumtion per IC? I guess a 15VA transformer should be enough for 8 IC's...?
Old 20th September 2013, 03:26 PM   #757
I just checked the 2092... so for everybody interested, the 2092 gets 11mA per rail (+-) with 5,4V. So yes, my 15VA transformer should do the job for the 8 amps...
Old 20th September 2013, 05:23 PM   #758
thank you
Old 8th October 2013, 10:30 PM   #759
wushuliu's Avatar
Originally Posted by redjr View Post
Noah,
I guess another way to describe these (2092 based) class D amps is that they are 'lively' compared to other SS or class A, A/B amps.
Interesting. The Classdaudio.com IRS2092 amps (that started the IR craze) do not sound lively or edgy or anything like that at all. By and large the feedback has been the opposite: laid back, warm, tubey. That's been my experience as well. However from time to time there have been users who say their experience is edgy, thin, etc. So I can't help but think there is a system matching thing to be figured out. My speakers measure pretty flat and the last word I would use to describe the classdaudio.com IR amps is 'lively'.
Old 9th October 2013, 02:44 AM   #760
redjr is offline redjr  United States
Perhaps it's my speakers then that produce that lively sound - but I don't necessarily think so. IMO, it's anything but tube-esk like sound. Having said that though, the only class D audio amp that I hold in esteem is the class D ICE amp modules that Pioneer uses in their SC-xx HT receiver line. I've said it before and I'll state it again; they are the smoothest amps I've heard this side of the high-end audio - which I've heard very little of. And they continue to best any class D amp I've built. For sure, Pioneer and AirStudios have optimized the sound for HT use, but even in Pioneer's Pure Direct mode (no DSP), I could listen to them for hours without any fatigue whatsoever. It's like smooth butter to your ears.
In fairness, my IRS2092 amp was connected to bookshelf speakers, so I wasn't ever listening at reference levels or trying to fill a large room with big sound. But those same, simple speakers sounded marvelous with the ICE amps. I say was, only because I don't currently have it hooked up to any system, since I just moved and in the process of building out my listening/mancave room.
Some people scoff at the little LJM 2092 modules, but for a budget amp I'm quite happy with the way they sound. I've never had one hooked up to a sub-woofer either, so that would make a big difference in the amount of bass I hear from my garden variety bookshelf speakers. To each his own I guess.
redjr
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 30th April 2017 06:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright 1999-2017 diyAudio
