My design L20D IRS2092+IRFI4020H 200W8R - Page 60 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st December 2012, 01:48 PM   #591
Originally Posted by Stammheim View Post
Hi guys,
I run the fresh built amps for few hours now. What I don't like is the heat from the resistors, although I run tthe L25D's with 60V only. Is there a better way by replacing these guys? Did anybody have problems with burnt resistors?
Thanks,
Stammheim
Yes, this is a known issue. Due to the higher rail voltages the resistors do run hotter. LJM chimed in and said it was all good, but others did not like it.
There has been previous discussion about this, somewhere in this monster thread. The end game is larger wattage ratings to lower the resistor heat. A post looked at the temps before and after, with real temp numbers
Old 21st December 2012, 04:34 PM   #592
DarpMalone's Avatar
Hi guys,
Thanks,
Stammheim
I'm running my L25D's @ 75v. I swapped the 2Watt resistors to 3W's. They still get pretty hot but I haven't had any problems.
Old 22nd December 2012, 03:06 PM   #593
Yeah, I've also read about the recomendation, but - as you write - the monster thread... I couldn't find it anymore...
I remember, somebody wrote about Mills resistors, but unfortunatelly it's not possible to get them in Germany...
So just replacing the 2W with 3W is OK?
Are there any bigger ones which are the optimum for this?
Many thanks, guys
Old 22nd December 2012, 04:26 PM   #594
doctordata's Avatar
Many thanks, guys
3 Watts are OK , hot is hot for us , but for a resistor , 75 degrees is winter , most resistors have a max operating temp of 150 degrees C so if your PCB can cope with that , there's no problem .
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 23rd December 2012, 03:57 PM   #595
Cheers ,
Rens
That's "cool"
Thanks!!!
I got another issue. After I heared hum from the speakers (8x L25D's), I measeured the amps with my oscilloscope. The scope showed me a sine of 2,5V and 400kHz without having signal-in. It's funny, that any amp has the same sine, so it might be normal using the L25D's, or I might have an issue with my SMPS's (both SMPS800RE from Connexelectronics, both with the same result).
Did anybody measure the amps and can help me with comparing?
Many thanks,
Stammheim
Old 23rd December 2012, 05:20 PM   #596
nigelwright7557's Avatar
The scope showed me a sine of 2,5V and 400kHz without having signal-in. It's funny, that any amp has the same sine, so it might be normal using the L25D's,Many thanks,
Stammheim
Its normal, my 2092 amps put out even more carrier on the output.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 23rd December 2012, 06:27 PM   #597
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
all oscillating amps do that, some less, some more, depends on the design
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 23rd December 2012, 10:22 PM   #598
Do I get you right? Your speakers produce hum, too? I'll try to measure the SMPS's hum with some resistors, so without the hum from the amps. Doesn't anybody have similar experiences or some measurements?
Are threre any mods so solve it?
Old 24th December 2012, 06:37 PM   #599
exflaco is offline exflaco  Armenia
Luka could eliminate complete these carrier? like crest lt series?
Old 24th December 2012, 06:49 PM   #600
doctordata's Avatar
Your speakers are not able to produce any output at 400 khz and if they could you would not hear it anyway
Cheers ,
Rens
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 28 15th January 2017 09:32 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 02:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 09:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 03:46 PM
Design help needed for IRS2092 cmhadley Class D 1 3rd January 2009 12:06 AM
Copyright 1999-2017 diyAudio
