Go Back   Home > Forums > Amplifiers > Class D
Old 11th September 2012, 01:54 PM   #541
MrSlim is offline MrSlim  Canada
Originally Posted by Jogi View Post
I am considering the L15-D mono modules and think about using a transformer with two 38V secondaries and 440Va, just because it is lying in the drawer. Should be o.K for the L15, as it uses lower voltage than L20.
The question is, if I can supply both modules from one +/- supply?
That means transformer--> rectification to ca 53 volt--> +22000µf/-22000µf--> 2 mono modules. Or do I get groundloops or something like this when not supplying each module by its own supply?
Thanks a lot for advice,
Juergen
You should be fine, most commercial amplifiers use a single power supply for two channels, that is unless they are using a fully "dual mono" design. I've got two L15D's running off a single 300R SMPS. It sounds great.
Old 11th September 2012, 05:46 PM   #542
Jogi is offline Jogi  Germany
Thanks, that's exactly what I wanted to read . Those amps seem to be a great value, I'll order soon. Nice project for the long autumn nights....
Old 24th September 2012, 04:13 AM   #543
DarpMalone's Avatar
I have a question for LJM or anyone else who can answer regarding the L25D.
If I change the appropriate resistors, will it operate @ +/-42v?... Approximately how much power can I expect into 8R / 4R (2x 420VA transformers)?
Old 24th September 2012, 10:18 AM   #544
Default +/- 42 Volts
Hi DarpMalone ,
Yes , It will work .
You'll get about 80 watts @ 8 ohms before clipping and double that @ 4 ohms .
See the reference design and calculate your resistors about in between the AMP7D-100 and the AMP7D-150 . Enjoy !
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 24th September 2012, 11:31 AM   #545
DarpMalone's Avatar
Thanks Rens. I guess I'll be ordering some L15-D's, in that case
Old 24th September 2012, 01:18 PM   #546
My class D Amplifier...
Old 1st October 2012, 03:16 PM   #547
Hi luizcpimenta,
can you give more informations, i.e. in what your design is different from LJM's, how it works, sounds etc? Just a layout with no infos isn't of much information.
Old 1st October 2012, 05:14 PM   #548
Originally Posted by portomomo View Post
Hi luizcpimenta,
It is exactly like the circuit LJM, except the bias, which put off the board.
Old 4th October 2012, 09:27 PM   #549
Thanks for share it to all
Old 4th October 2012, 09:29 PM   #550
Are you have part list for your amp?
What about protection?
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 09:10 AM
IRS2092 Amp Design Review brent113 Class D 22 17th June 2010 05:30 PM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright ©1999-2013 diyAudio
