My design L20D IRS2092+IRFI4020H 200W8R - Page 50 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 17th July 2012, 07:57 PM   #491
Hi
I have bought the l20d and ordered the Connex SMPS 800r aux 12 power supply. Now i am considering connecting a pair of VU meters to make my amp glow in the dark. Do you think it is possible use this from ebay: 2Pcs VU Panel Meter Warm Back Light + VU Driver PCB Board Stereo For Audio Amp | eBay ?
Thank u in advance :-)
Old 18th July 2012, 02:10 PM   #492
Hi guys,
reading the thread a long time I decided to build another L25D-amp. Cause just waiting for another SMPS from Christi, I got some time for optimizations. I decided for the SMPS800RE this time. Which components of the L25D should be replaced to get a better result?
It would be nice to summerize a sheet with all optimizations, so anybode has a overwiev what is possible by replacing which component.
Many thanks,
Stammheim
Old 20th July 2012, 12:52 PM   #493
Hey guys...
No idea or are you all gone for another amp???
Br,
Stammheim
Old 22nd July 2012, 01:24 PM   #494
Originally Posted by jlester87 View Post
Does this have a built in over current protection? Anyone tried shorting speaker outputs?(either intentionally or accidentally)
Hi LJM, Reposting my question...
Do I have to add over current protection?
Old 22nd July 2012, 01:27 PM   #495
Here's my L25D running at +-53VDC, resistors adjusted to accommodate this voltage.
(Thin wires of second channel and amp layout are just temporary)
Very good sound stage and airy sound, but the treble/high sound is a bit dry. I think I might need to upgrade the input cap and add a tube buffer to achieve sweet sounding highs...
Old 24th July 2012, 09:02 PM   #496
Hey...
nothing to optimize?
Old 2nd August 2012, 03:15 PM   #497
doctordata's Avatar
Originally Posted by Stammheim View Post
Hey...
Hi Stammheim ,
I changed the input capacitors ( of my L15D's ) with Silmic II's 22 uF/50V and increased the buffer caps to Panasonics 820uF/63V ( wich will fit on the PCB) Rs partno. 571521, wich should be fine with your rail voltage .
The difference is not huge but it's there . Highs are a little bit more sparkling and some more punch in the mid lows.
I'm loving these amps ,together with my Emotiva UMC-1 and 5 Tannoys and the (regulated) powersupply (A1000SMPS) from Connexelectronics it is a superb combination .I have a couple of much more expensive amplifiers , but did only listen to the LJM's for the last month because overall they sound the best .
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 2nd August 2012, 03:26 PM   #498
doctordata's Avatar
Sorry just read the messages again and was assuming you where using 53 volt rail voltage , ( jlester87 ) so forget about the Panasonics .
Cheers ,
Rens
Old 2nd August 2012, 03:42 PM   #499
I actually think I am going to change out basically anything in the signal path except for the inductor at the output, since I am already modding my boards to accommodate 35V +/-
This list will include:
CP1 - 22uF
R2 - 330R
R7 - 3k01
C4 - 1nF
C6 - 1nF
I will probably follow doctordata's example and use Elna Silmics at the input. Would it be dangerous to put a film bypass paralleled with CP1, assuming I can find a way to fit it?
I may also swap the 470uF 100V caps for higher value, lower voltage, since they only need to handle 35V each. A nice 50V or 63V variety (also per doctordata) would work, correct? EDIT: as long as it is no more than 16mm wide
Old 2nd August 2012, 05:52 PM   #500
Actually, I might just swap out all of the 22uF 25V caps while I am at it with Elna Silmics. There are six per board. I may also order some 22nF MKP caps to parallel across CP1 on each board.
I will have to check when I get home whether the buffer caps in the L20D are actually 470uF 100V (per reference design) or 100uF 80V (per board markings). I think I will sub them with 470uF 50V Nichicon KZ caps.
I can't seem to find a good replacement for the 1nF ceramic caps (C2,C4,C6,C7) since they are so small, so I may just leave them in place. I was trying to find a comparable WIMA cap, but they all seem to be much too large.
R2 and R7 will probably be swapped with 1% Vishay/Dale resistors of the appropriate values.
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 31 Yesterday 09:36 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright 1999-2017 diyAudio
