Go Back   Home > Forums > Amplifiers > Class D
Old 13th May 2012, 11:34 PM   #461
u should replace the caps in the ps board.
Old 13th May 2012, 11:43 PM   #462
dudaindc's Avatar
Which ones and why? Maybe I missed something...
Rubycon || Nichicon
Old 13th May 2012, 11:50 PM   #463
the big black ones they are fakes just random sized caps pulled out of other electronics.
Old 13th May 2012, 11:50 PM   #464
Yeah i thought so to! they seem insanely cheap! Any recommendations?
Old 14th May 2012, 12:01 AM   #465
in the usa sure but in Norway i have no idea u just need 10kuf 80v 10mm leads
Old 14th May 2012, 12:04 AM   #466
Will better Capacitors, improve the sound in anyway?
Old 14th May 2012, 12:10 AM   #467
probably not but the caps could fail and destroy the amp boards and worse case would be start a fire and burn down your house ofc insurance wont pay out either in the case this happens but u might save $50 in caps worth it up to you
Old 14th May 2012, 12:10 AM   #468
dudaindc's Avatar
Thanks for the warning!!!
Rubycon || Nichicon
Old 15th May 2012, 08:02 AM   #469
clm811 is offline clm811  United States
clm811's Avatar
Since I will be using a power supply of approx +/-72vdc to +/-75vdc, I will be replacing the 2W resistors with 5W ones; additionally, the stock heat sink will be replaced with 76 x 50 x 22.2mm one, with a 5mm thick baseplate. I expect the devices to run noticeably cooler than stock. My speakers are 4 ohms.
The amps will look like this:
Old 16th May 2012, 07:45 AM   #470
Hi LJM,
Any plan to release a version with a provision for mountable heatsink underneath the board? So that we can easily replace the stock heatsink...
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 09:10 AM
IRS2092 Amp Design Review brent113 Class D 22 17th June 2010 05:30 PM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright ©1999-2013 diyAudio
