| Class D Switching Power Amplifiers and Power D/A conversion |
#451 |
I have not seen any wiring information with LJM's new board power supply + speaker protection board.
Will be glad if any one could point me to the specific post. Thank you |
#452 |
Received my L25D Boards, and everything looks good, except:
There was no thermal compound on the H669A BJC or IRFB4020's, so I applied some. While operating at approximately 10wattsrms, the H669A BJC and three green resistors got very hot(could not keep finger on it for any time). ![]() For this thing to be capable of 300W I believe a larger heat sink will be needed. Opinions, or similar experience to share? -Chas |
#453 |
Its surprising how small a heatsink you can get away with for class d.
I test my 750 watt amps on full power for a few seconds with no heatsink and the transistors dont get hot. Components can run very hot yet still be well inside their SOA. Power resistors do tend to run hot anyway.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#454 |
hi,on my L25D the two rezistors from 5V6 diodes are at 40 degrees and the on at the NPN tranzistor has allmost 60 degrees yet the amp works non stop over 1 month
#455 |
So i just finished my l25D amp. with a 650watt 2x50vac and 60 000uF psu thats feeding the boards with 70vdc.
When i crank up the sound to very high volums one of the bords just shuts of and the otherone continiue. Then i have to turn the volum a little down and it comes back! Any ideas why? |
#456 |
the amp reaches hard clipping and protection mode is activated!
#457 | |
But how is it possible to Get clipping from a 250w amplifier.. When its impossible to get the Rotel RB1070 with its puny 125w to go into protection mode! Last edited by solviken; 13th May 2012 at 04:03 PM. |
#458 |
read the application note for irs2092
#459 |
Will do
#460 |
I thought that i should share my Almost finished L25D project
Still havent added the Speaker protection board, cause i dont have anything to power it with ATM.Here are som pictures! ![]() IMG_4605.JPG IMG_4606.JPG IMG_4614.JPG IMG_4618.JPG IMG_4626.JPG |
| IRS2092 Amp Design: Please help! | Devendra | Class D | 11 | 17th March 2011 09:10 AM |
| IRS2092 Amp Design Review | brent113 | Class D | 22 | 17th June 2010 05:30 PM |
| IRS2092 help! | yudi02 | Class D | 2 | 11th October 2009 03:30 AM |
| Design help needed for IRS2092 | cmhadley | Class D | 1 | 2nd January 2009 11:06 PM |
