My design L20D IRS2092+IRFI4020H 200W8R - Page 36 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 10th March 2012, 01:31 PM   #351
MrSlim is offline MrSlim  Canada
Originally Posted by solviken View Post
Thanks for answer But if i Bridge L15 would it be stable in 4 and 2 ohm? Was thinkin of using it as subwoofer amp!
The Reference Design shows the bridged rating for 8 ohms only.. so I would suspect no.. (4 and 2 are probably too low, something is going to loose its magic smoke..
Old 10th March 2012, 01:47 PM   #352
alkasar is offline alkasar  France
But if i Bridge L15 would it be stable in 4 and 2 ohm? Was thinking of using it as subwoofer amp!
Remember that in a bridged amp, it is as if each half-bridge "sees" half of the load. Bridged amps usually target 8ohm and more loads. They rarely support 4ohms or you would have to drastically limit the power. Opposite to your goal.
Old 10th March 2012, 01:53 PM   #353
Originally Posted by MrSlim View Post
the L25D is even higher power than it (a variant not discussed in the Ref Doc).
isn't L25D an exact implementation of IRAUDAMP7S as in page 30 of the ref doc with two fets per channel ?
http://www.inductor.com/irf/iraudamp7s.pdf
Old 10th March 2012, 04:32 PM   #354
re-read my sentance above. really unclear
to make it simple, it seems to me that 2xIRFB4020 mosfets are functionnally equivalent to 1xIRFI4020 half-bridge integrated package.
Do I miss something ?
Old 10th March 2012, 06:57 PM   #355
Yes functionally the same, however you missed something
IRF4020H-117P = Id at 100 deg C = 5.7 Amps Cont.
http://www.irf.com/product-info/data...4020h-117p.pdf
IRFB4020PBF = Id at 100 deg C = 13 Amps Cont.
http://www.irf.com/product-info/data...rfb4020pbf.pdf
You should see the Pd numbers, its almost shocking to see the difference between the two.
This is why I am a fan of the L25D from LJM and the L25DE from hien.t.nguyen for use with 8 Ohm speakers
Old 11th March 2012, 01:12 PM   #356
yes, seems that two single mosfets are more efficient than a couple
makes me believe that L25D is better suited for 4ohms than L15D.
Old 11th March 2012, 02:15 PM   #357
I believe the THD and noise floor is better with the L15 per LJM, you can get more power from L25 into 4 ohms, you better have a larger heatsink or a fan. I think you could blow away the power nameplate rating with proper cooling. The only drawback I see to the IRS designs is the heatsink is central to the board, menaing when really pushing it for long periods a fan is necessary. I am going to do a multichannel IRS amp using one of the two design mentioned above, my hangup is the fets not being moved to the perimeter like the LM3886/4780 kits
Old 12th March 2012, 06:09 AM   #358
DarpMalone's Avatar
I finally got around to building my L25D boards and linear power supply... One board works fine but for some reason the other one has a very loud hum. All of the solder joints seem alright. I'm not sure where to begin troubleshooting... Anyone have any ideas?
Old 13th March 2012, 02:20 PM   #359
DarpMalone's Avatar
No suggestions? I figured this would be the best place to ask
Old 13th March 2012, 02:25 PM   #360
s3tup's Avatar
DarpMalone, show some pics of your setup.
"hum" tests should be done with shortened inputs. Each input to it's ground.
If the hum stays, it means the amp is the source of it. Therefore we can start troubleshooting the amp, and not it's surrounding.
"hum" is 60-120Hz? Or noise?
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 28 15th January 2017 08:32 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright 1999-2017 diyAudio
