My design L20D IRS2092+IRFI4020H 200W8R - Page 23 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 30th October 2011, 12:25 AM   #221
Originally Posted by trevmar View Post
...the main capacitors measured 0.12 ohms ESR and so were headed to the junkheap as soon as they crossed my doorstep, as I draw the line at about 0.05 ohms right now
Does the ESR affect sound quality and/or efficiency/heat (do these pass output current?)
Also curious about your opinion on use of electrolytics as blocking caps on the input; did you change those?
Originally Posted by ljm_ljm View Post
I'm going to see this circuit, that you should be calculated is correct.
Reverse phase input virtual ground, so input impedance should be 1 / (1/100 K + 1/3.33 K)
Thank you for your correct.
Is this correct? What about R8, 120k?
This is important to me so I can properly calculate a passive shelf filter to correct an issue with my L/R speakers.
Noah
Old 30th October 2011, 04:55 AM   #222
I'm confused on the correct values for the main caps, shown on p.21 fig.25 here
http://www.inductor.com/irf/iraudamp7s.pdf
If my rudimentary understanding of circuits is right, they're CP7 and CP8.
I wonder why they're "CP" and not just "C", and why they're printed in red and have asterisks in front of the 470uF.
Noah
Old 30th October 2011, 05:07 AM   #223
MrSlim is online now MrSlim  Canada
From the BOM , it looks like the CP's are electrolytics , and the C's are non electrolytics..
Old 30th October 2011, 05:15 AM   #224
ah right, P for polarized
Noah
Old 30th October 2011, 05:35 AM   #225
ljm_ljm is offline ljm_ljm  China
Originally Posted by pheonix358 View Post
Hi all, nice thread, nice amps!
I am a little confused. I assume I can only purchase these on Ebay.
eBay My World - along1986090
eBay My World - zoe_tsang
Both of these sellers have them. Is one better than the other? Are both authorized to sell them?
Thanks in advance
Terry
Yes, there are two authorized only.
Old 30th October 2011, 05:37 AM   #226
They are inverse the amplifier circuits, there are many material are described in content.
Before I ignore this, in the capacity of the capacitance on use size, 22 UF is more reasonable.
So we don't have to change it.
Old 30th October 2011, 07:28 AM   #227
My question is not about the 22uF value, it is whether it is advisable to use a nonpolarized electrolytic capacitor for an AC audio signal.
Noah
Old 30th October 2011, 06:26 PM   #228
I thought that crossover distortion wasn't an issue for class D because they don't construct the output waveform from two halves like AB designs, but then I came across this:
Originally Posted by phase_accurate View Post
Class-d in general do have a very different crossover behaviour than linear amps. There is always an alternating idling current flowing through the output inductor at no or low output power. This current is greatly supporting the switching process. At the very point when the output current in the load approaches the value of the idling current a class-d amp's crossover takes place. This is usually at a few watts. There are amps where this is intentionally pushed to higher output power levels by the use of smaller inductors (and therefore increased idling current).
Is this true for the IRS2092-based modules?
If so, what is the freq of this alternating idling current?
The only evidence is a small bump at 20W in some of the THD+N vs. power graphs, but curiously only in one channel.
Noah
Old 31st October 2011, 01:17 AM   #229
ordinary power amplifier is the same. Of course can use any capacitors.
Old 31st October 2011, 05:14 AM   #230
It's probably the self generated 400Khz frequency that is used as part of the Class D design..
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 30th April 2017 06:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright 1999-2017 diyAudio
