My design L20D IRS2092+IRFI4020H 200W8R - Page 22 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 27th October 2011, 09:38 AM   #211
RobLK is offline RobLK  United States
Hi ljm_ljm,
Which speaker protection board do I use for the l25d?
Old 27th October 2011, 01:30 PM   #212
DarpMalone's Avatar
If the L25D has higher current capability and they both run on the same voltage range, what would be the advantage of using the L20D over the L25D?
Old 27th October 2011, 02:02 PM   #213
MrSlim is offline MrSlim  Canada
Originally Posted by lithoc View Post
Hi LJM,
What's the inductor rating & value compare with L15 & L20?
Instead using 2 4020H , you can use 2 4227 (without buffer) ?
4227 can drive 4 ohm at high voltage or 2 ohm at low voltage.
The inductor is the same for the L15 and L20, 220 uH, 13A..
If you tried using the 4227, to drive higher current into 2 ohms, you'd have to at least switch the inductor to a 7G31A-220M-R which has a 31A rating.. (notwithstanding, you'd probably be doubling the cost of the modules with those two component changes alone (single unit price is 2x for the 4227 and 4x for the 7G31A))
LJM would have to comment on what other changes would be required..
Old 27th October 2011, 03:05 PM   #214
theAnonymous1's Avatar
IRS2092 and IRFx4227 don't play too nice together. The 2092 is barely able to drive them, and you need to set dead time to max and settle with a lower switching frequency.
Old 28th October 2011, 05:11 AM   #215
lithoc is offline lithoc  Malaysia
lithoc's Avatar
If I remember correctly, 4020 output is 9 amp, using 2 should be able to output at 18amp ?
Can the inductor handle 4 ohm speaker?
But again, LJM specifically said it's 350 watt for 4 ohm.
I guess the inductor is the limitation and costing as well.
cheers ..
Old 28th October 2011, 06:09 PM   #216
ljm_ljm is offline ljm_ljm  China
cheers ..
Yes, I try various low cost but they don't let me inductance satisfaction.
I have seven G31A the inductance, it's expensive, and need 1 K number above just have the order.
It made him feel is not effective. I don't know the actual use of whether there is a need to output so big of current.
I seldom see less than 4 ohm speakers. You feel really necessary? Maybe in small power may not better listen to sound.
Old 28th October 2011, 06:15 PM   #217
Originally Posted by RobLK View Post
Hi ljm_ljm,
http://www.diyaudio.com/forums/attac...rfi4019-bf.jpg
Convenient installation. Laugh.
Old 28th October 2011, 06:17 PM   #218
Very right. We need to consider the practical.
Old 29th October 2011, 05:05 PM   #219
Originally Posted by trevmar View Post
Thanks for posting this info, LJM. I am building a modified Linkwitz Pluto with a Peerless Tymphany 890983 'tweeter' as I don't like the resonance in the Aura 'tweeter'.
I have bought a miniDSP board instead of the Linkwitz analog filters, it works well. I am looking for some amplifiers to use to drive the Seas L16RN. They are rated at 80W sinewave and 250 Watts peak IEC longterm noise. I had chosen to use the (bridged) TDA8920BTH boards from Yuanjing, but they oscillate at 50KHz rather badly, and I can't dampen it by changing the output inductors. Must be a grounding problem. So it would seem that I should invest in a higher voltage transformer and a pair of L20 boards I am happy with the TDA7293 boards I bought for the tweeters. Power for the 890983 is somewhere between 7W and 60W, depending on which Peerless data sheet revision you are reading (v1 or v2) so the TDA7293 has plenty of power and looks really nice and clean on my oscilloscope, just what I need for a tweeter, I think
So congratulations on getting the L20 stable, I will order a pair and let you know what I think.
Happy Summer -- I was in Dalian in April and May, and Shanghai in June, but I do remember the heat when I spent August in Chengdu during 2009 -- it is very hot indeed. Much more pleasant here in California, I think We don't even need air-conditioning (just heating for winter). Thanks again for the help...
My English is not good, the software seems a bit faster than my translation.
But the software is always miss the lower content.
So you come to chengdu's accident. Here is a climate change is very obvious place.
Old 29th October 2011, 11:58 PM   #220
pheonix358's Avatar
Hi all, nice thread, nice amps!
I am a little confused. I assume I can only purchase these on Ebay.
eBay My World - along1986090
eBay My World - zoe_tsang
Both of these sellers have them. Is one better than the other? Are both authorized to sell them?
Thanks in advance
Terry
What we don't understand is called magic.
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 28 15th January 2017 09:32 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 02:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 09:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 03:46 PM
Design help needed for IRS2092 cmhadley Class D 1 3rd January 2009 12:06 AM
Copyright 1999-2017 diyAudio
