My design L20D IRS2092+IRFI4020H 200W8R - Page 16 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 26th September 2011, 01:51 PM   #151
My preamp mounted an 0,47uf teflon caps and 1Mohms parallel resistor in output, is possible bypass a electrolitics caps of 22uf mounted in L20D input for a best sound?
Old 26th September 2011, 02:26 PM   #152
ljm_ljm is offline ljm_ljm  China
I'm sorry I'm not quite understand your meaning.
L20D input capacitance can't cancel, also do not have to change.
The capacitance of the quality is very good, even more than the IR company provide the IRAUDAMP7S above the capacitance
Old 26th September 2011, 03:07 PM   #153
But 22 UF can parallel MKP 0.1 UF
Old 27th September 2011, 11:49 AM   #154
ok, but I can change this caps with a non polarizzed caps? ( I have a 22uf petp caps)
Old 27th September 2011, 04:45 PM   #155
The capacitance can be replaced, or better capacitance.
Best capacity is more than 10 UF. But must not cancel the capacitance
Old 27th September 2011, 11:54 PM   #156
Bernie7 is offline Bernie7  Singapore
Is the input 22uf capacitor for DC blocking only, or does it do more
Old 28th September 2011, 12:03 AM   #157
nigelwright7557's Avatar
The input capacitor forms a filter with the input resistor.
3k3 and 10uf gives a break point of around 5Hz.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 28th September 2011, 01:25 AM   #158
If no input capacitor, IRS2092 will not work.
In fact the larger of the capacitor is more small capacitance distortion.
Old 28th September 2011, 01:51 AM   #159
I am listening to the L20D now with the input caps shorted, and it's not only working but sounding mighty fine across the entire freq range, giving more extended and detailed top end.
The input cap forms a high pass filter with the input 3.3K and this imposes a low freq cutoff, but no cap means no cutoff, no?
What am I missing - why is the input cap mandatory if my source is AC coupled?
Old 28th September 2011, 02:19 AM   #160
Amazing.
If you can use if you are free to use.
But I am not very suggested that such, it gives some dangerous.
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 30th April 2017 06:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright 1999-2017 diyAudio
