My design L20D IRS2092+IRFI4020H 200W8R - Page 14 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 18th September 2011, 09:20 PM   #131
this power supply is ok for this amplifier:
6*10000uF/80V high quality power supply board for amp | eBay
this trasformer is ok for the amplifier and this power supply: +45v,45 - 500VA
Old 18th September 2011, 09:36 PM   #132
sorry for two message
This is a first message in the forum's in my life.
Old 19th September 2011, 06:22 AM   #133
ljm_ljm is offline ljm_ljm  China
Originally Posted by hreith View Post
Input-Impedance = 1/[(1/100k)+(1/3.34k)]=3.23k
They are not parallel
You can use the multimeter, measure the IN +-between the resistance value.
This is the dc resistance.
If the input capacitance, no before and after the resistance of the parallel, then dc resistance = exchange impedance.
Old 19th September 2011, 06:30 AM   #134
R2 C2 is a low-pass filter, frequency is 482 K-3 DB
Old 19th September 2011, 06:32 AM   #135
GOOD.
Transformer, but no reversals double AC45V, 500 W of transformer is very appropriate.
The power only need greater than 2 * 10000 UF 80 V is very good.
Too big words like nothing the disadvantages.
Old 19th September 2011, 06:36 AM   #136
hreith is offline hreith  Germany
hreith's Avatar
Hi ljm_ljm ,
Your Design is an inverting Amp. There ist no Signal-Difference between Note R7-R8 and GND.
Old 19th September 2011, 07:21 AM   #137
Hi ljm_ljm ,
HI.
HI. Very nice of you to answer.
I'm going to see this circuit, that you should be calculated is correct.
Reverse phase input virtual ground, so input impedance should be 1 / (1/100 K + 1/3.33 K)
Thank you for your correct.
Old 19th September 2011, 07:27 AM   #138
Input capacitance in 22 UF can about 2.2 HZ -3 DB
I suggest using more than 10 UF
Old 19th September 2011, 01:55 PM   #139
Originally Posted by ljm_ljm View Post
GOOD.
sorry, the trasformer 500VA for one channel (dual mono configuration) or one trasfo 500VA for two channel?
Old 19th September 2011, 02:07 PM   #140
Very enough. You want to know how much you need to use the power output.
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 Yesterday 06:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright 1999-2017 diyAudio
