My design L20D IRS2092+IRFI4020H 200W8R - Page 10 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 7th September 2011, 03:21 AM   #91
dewardh is offline dewardh  United States
Two arrived today, will be re-working for lower gain and lower (42V) supply. Yep, no thermal paste at all . . . will be treating like semi-populated "project board" . . .
Old 7th September 2011, 03:43 AM   #92
ljm_ljm is offline ljm_ljm  China
Originally Posted by cOz View Post
How can we be sure that the board we purchase is not pirated and is to spec of the original design? Does ljm_ljm sell them officially somewhere? If there are differing designs where are the differences described in detail?
L20D I have more strict production material requirements.
Including military level of materials of the PCB, plating.
Low temperature wave metal resistance, and use of Japanese make capacitors.
No matter what the time these are not change.
Old 7th September 2011, 03:51 AM   #93
Originally Posted by petegt View Post
Thanks for this information. The 2k2 1W has definitely changed colour on my working board.
I am struggling to find these values though.
1W 6K2 - Would 1W 5K6 be suitable?
1W 3K - Would 1W 3K3 be suitable?
my board does not have 80V 150UF it has 63V 100UF.
was 2200UF a type error? Did you mean 220UF? 100v
YES。
Increase 1 W to 1 W6K2 5 K1, 5 K6 can also.
Increase 1 W to 1 W 3 2 K2 erp
Electrolytic use 100 V 100 UF-220 UF. In the radiator to the right of the two.
Old 7th September 2011, 03:59 AM   #94
Originally Posted by alkasar View Post
Hello,
I would like to use L20D board for a 4ohms subwoofer. This sub is controlled by a servo and will really use close to 300W at the lower frequencies.
To achieve 300W in 4ohms, +-52V rail powersupply should be sufficient.
as trevmar mentioned, the iraudamp7s reference design pdf, fig5, shows reasonnable THD measures up to 300W with +-50V supply. This is with 4019H. 4020H should behave even better.
ljm confirmed 4020H is limited to about 9A continuus, leading to 9*4=324W max in 4 ohms. Looks good
L20D board specs is 60 to 80V. Will it work well with +-52V ?
+ -52V 4ohms。
I suggest you to change only 8 resistance.
130K 1/4W - 120K 1/4W
5K1 1W - 3K3 1W (2PCS)
2K2 1W - 1K 1W
20K 1/4W - 15K 1/4W
5K1 1/4W - 7K5 1/4W
8K2 1/4W - 9K1 1/4W
75K 1/4W - 47K 1/4W
Do not need to change the IRFI4020.
Or, you can consider to use L15D, L15DX2.
They are IRAUDAMP7S -150
Use the +-50 V, 250 W * 2, 4 OHM
Old 7th September 2011, 04:29 AM   #95
cOz is offline cOz  United States
Where do you sell your pcb modules?
Old 7th September 2011, 08:18 AM   #96
Bernie7 is offline Bernie7  Singapore
Just received my L20D modules.
Is a cap used to decouple DC at the input, or is there no decoupling cap?
If so which cap? I may want to replace with a better quality film cap.
Old 7th September 2011, 11:42 AM   #97
22 mfd electrolytic. Probably not the best choice.
Old 7th September 2011, 01:51 PM   #98
What's the input impedance of L20D? Need this to determine blocking cap value.
Old 7th September 2011, 02:19 PM   #99
About 3.4k. You can get all the answers you need from:
http://www.irf.com/technical-info/re...iraudamp7s.pdf
and
http://www.irf.com/technical-info/appnotes/an-1138.pdf
You may not need input blocking, depending on your application . . . if your pre-amp/crossover has either AC coupled output or servo control of its output offset. Much depends on how you're actually using the L20D . . .
Old 7th September 2011, 02:33 PM   #100
In EABY there should be sold in China, there are some dealers in doing international trade.
If has the question to the original confirmation. Can send photos to me
ljm_ljm@foxmail.com.
I found no L20D have temporarily of piracy.
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 28 15th January 2017 09:32 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 02:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 09:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 03:46 PM
Design help needed for IRS2092 cmhadley Class D 1 3rd January 2009 12:06 AM
Copyright 1999-2017 diyAudio
