My design L20D IRS2092+IRFI4020H  200W8R
Old 24th December 2012, 09:19 PM   #601
Stammheim is offline Stammheim  Germany
Yes of course I know... but that's what my oscilloscope says... the speakers say hum...
Old 25th December 2012, 11:47 AM   #602
doctordata is offline doctordata  Australia
doctordata's Avatar
I was just kidding , but you probably have some ground loop problem , Be sure to use a star ground , all grounds to one point at the PSU ( see my system picture in my previous post) I had a little hum in my 5 x L15d system in the beginning , when I wired the speaker grounds direct to the L15D boards . after I changed the speaker ground wiring directly to the star point at the PSU the system was totally quiet .
Cheers
Rens
If you measure, you know; if you guess, you don't
Old 25th December 2012, 01:05 PM   #603
exflaco is offline exflaco  Armenia
heyyyyy merry Christmas 4 All diyers
Old 27th December 2012, 07:10 AM   #604
luka is offline luka  Slovenia
luka's Avatar
Do I get you right? Your speakers produce hum, too? I'll try to measure the SMPS's hum with some resistors, so without the hum from the amps. Doesn't anybody have similar experiences or some measurements?
Are threre any mods so solve it?
well yes, but not because of the switching amp. you can't hear that freq. of several 100kHz. my hum if I would put it like that is because of not really good ground between computer, power outlet and amp and so on. with no signal, no cable on input, you can't hear anything
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 27th December 2012, 08:19 AM   #605
I know what you mean and I don'r really know the problem. I also know I'm not able to hear > 16 - 18kHz. But I can hear the hum from the speakers really good, and after I simply wired only one module and solved any possible loops, I have no idea instead. Is it possible, that the SMPS' s ripple / AC is too high and so the mosfets or other vomponents are oscillating?
Old 27th December 2012, 09:48 AM   #606
peterhenk is offline peterhenk  Netherlands
Cheers
Rens
Hi Rens,
So to make this clear for me
Your speaker ground goes both (first) to the common star ground and (then) to the minus binding post on the L15d.
I have some his that I would like to tackle, this is by far the easy way out.
Thank you
Peter
Old 27th December 2012, 10:30 AM   #607
doctordata's Avatar
Default Noise
I wired my amp as described in post 47
http://www.diyaudio.com/forums/class...ml#post2687712
That solved my ( modest) hum problem .
Dont think it will make any difference with noise . My amps have very little noise , only audible with the ear in front of my very sensitive Tannoys .
Cheers ,
Geniet van de oliebollen ! (Enjoy the Oil Balls!)
Rens
Last edited by doctordata; 27th December 2012 at 10:49 AM. Reason: Translating Dutch phrase
Old 27th December 2012, 10:38 AM   #608
Default Begrepen
Hi Rens,
I use the L15d-pro. Just searched for the recommended wiring, as it is different because of the incorporated speaker protection.
So your solution will not work for me.
Oliebollen / appelflappen: we zullen er zeker van genieten!!
Groet
Peter
Old 27th December 2012, 11:00 AM   #609
doctordata's Avatar
Default His , Hum or what
Originally Posted by peterhenk View Post
Hi Rens,
Groet
Peter
Hi Peter ,
Do you have noise ( Hiss) or hum in your system , I don't have a schematic of the l15D pro with DC protection , but have a pretty good idea how it is wired on the PCB and I think there will be a problem in a multi amp system on one PSU with this board .Do you have the schematic ?
Cheers ,
Rens
Old 27th December 2012, 11:53 AM   #610
Hi Rens,
The schematics of the wiring.
I use a connexelectronics smps500r to feed them.
My grounding is floating as I have no grounding in my sockets.
Peter
My design L20D IRS2092+IRFI4020H  200W8RHide this!Advertise here!
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 30th April 2017 06:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
