My design L20D IRS2092+IRFI4020H  200W8R
Old 26th June 2012, 09:55 PM   #481
blairfrischx is offline blairfrischx
Originally Posted by alkasar View Post
I am done with the reverse engineering to cross-reference L25 board.
For memory, the original IRAUDAMP7S is here, page 30
http://www.inductor.com/irf/iraudamp7s.pdf
L25D cross reference
http://img407.imageshack.us/img407/4...ationwithr.png
The design follows almost exactly IRF reference design.
some comments:
- The components values on the board follow the reference design, except for those to adjust according to power (in red in the schematic)
R7, R8, R17, R18, R12, R114, R115, R117, CP7, CP8
- pot P1 is not there. Instead, R11 is adjusted to 300R (resistor already sold on board)
- The protection led signal is not implemented (R14, CSD1, FET2, R3, D1)
- There is an additional 15V Zener, not on the schematic. Z? on board, already soldered. It is between pins 13 and 15 of IS2092
Sorry to bring this back from a long time ago, but I am looking to run an L25D at a lower voltage (35VDC +/-).
Would I be correct in interpreting the above post and others in this thread as meaning that it IS possible to run the L25D below the 60-70V +/- recommended range? If so, does it simply require changing a few resistors, as denoted by the reference document from IRF?
If I were at the beginning of this project, I wouldn't be asking this. I got all the way through construction and voltage testing before realizing my oversight. Someone help so I don't have to buy new amp boards?
Photo Album - Imgur
Old 26th June 2012, 11:27 PM   #482
MrSlim is offline MrSlim  Canada
In Theory, yes, you should be able to adjust the resistor values and get it to run at 35V, but to my knowledge, I don't know of anyone who has done it..
Someone has to be first..
Old 27th June 2012, 01:30 AM   #483
Well the other option is to drop another $100 on new 50Vx2 toroids for the two amps. I think a couple dollars in resistors and some time is a better investment currently.
So, that entails:
R7 - Not listed in Table 5; 3.01K in Figure 33)
R8 - 100K
R17 - 33K
R18 - 4K7
R12 - 3K9
R114 - 220R, 1W
R115 - 10K
R117, R118 - 2K2, 1W
CP7, CP8 - Not listed in Table 5, presumably unchanged for lower voltage
The only other thing that is red in Figure 33 is FET1, which I assume will remain unchanged because its specs do appear to allow for 35VDC operation. Output power will be cut down considerably into an 8 ohm load.
Or I could swap the transformers out, get ~70VDC +/-, and enjoy not having to solder a bunch of components. Decisions, decisions.
Old 27th June 2012, 10:54 AM   #484
michaelkkk is offline michaelkkk
we made 2092 amp years ago, we found its frequency range larger when heavy load.how difficult to use it in pro audio equipment , EMI and radio influence are hot potato. guys have good suggestion?
Old 30th June 2012, 11:33 PM   #485
So, that entails:
R8 - 100K
R17 - 33K
R18 - 4K7
R12 - 3K9
R114 - 220R, 1W
R115 - 10K
Some good news and some bad news here.
Good news first - it functions at 35V +/-
See that little blue light? Beautiful.
All that was necessary was swapping out the resistors as noted in the quoted post.
Now, on to the bad news. After removing, modifying, and rewiring the amp board in the one amplifier, I turned power on and POOF. Smoke. I accidentally wired DC+ to the wrong terminal on the board, and it fried something on both boards. The power supply rectifier/filter board was easy enough to fix - remove burnt traces and replace with thin wires. The amp board is another story entirely. I fear I may have burned up the opamp, rendering it useless. There are no obviously burned traces on the PCB or components, and yet it does not function, and the pretty blue light does not function.
Anyway, that's a problem that is simple enough to solve by buying a new amp board, replacing the resistors, and not wiring incorrectly. This post is more to announce to everyone that it is possible to swap resistors and operate at lower voltage.
Now here's an album of the project so far: Photo Album - Imgur
Old 30th June 2012, 11:52 PM   #486
momomo67890 is offline momomo67890  United States
good thing the boards are cheap
Old 1st July 2012, 10:04 AM   #487
JLesterP is offline JLesterP  Philippines
Yes, It is definitely possible.
I also changed some resistor values according to spec sheet and now I'm running my l25d at +-53VDC
Old 8th July 2012, 09:09 AM   #488
spirovious is offline spirovious  India
spirovious's Avatar
How is overall sound quality?Is it comparable to hifi power amps?
Old 13th July 2012, 05:10 PM   #489
doctordata is offline doctordata  Australia
doctordata's Avatar
Sound quality is very subjective , but for me they sound very good ( L15D) .
I own several amps , vintage Dynaco Stereo 400 , Denon AV3808 and a Luxman 590 . for me the overall sound off the L15D's is a bit better than the Dynaco, much better than the Denon and equal at low volumes with the Luxman or a bit less with some music .the Lux gives some better image and more detail , at Higher volumes they are sounding better then the Lux .
Noise is quite a bit higher , but not noticable 20 cm from the speakers ( 93db/w Tannoys) In my home theater setup with Emotiva UMC-1 they are absolutely stunning ! Even some commercials on TV are fun to listen to!
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 13th July 2012, 07:40 PM   #490
dudaindc is offline dudaindc  United States
dudaindc's Avatar
Sorry to hear about the "accident"...
I have a couple of questions if I may:
#1 - Did you use a Par-Metal chassis? If not, which one?
#2 - Where did you get the PSU boards?
Thanks!
"All measurements are wrong! Thus, measurement is the art of handling errors."
My design L20D IRS2092+IRFI4020H  200W8RHide this!Advertise here!
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 30th April 2017 07:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 02:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 09:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 03:46 PM
Design help needed for IRS2092 cmhadley Class D 1 3rd January 2009 12:06 AM
