My design L20D IRS2092+IRFI4020H  200W8R
Old 29th February 2012, 05:12 PM   #321
alkasar is offline alkasar  France
received mine. Nice boards indeed. Chip, two 15V diodes and one resistor presoldered. Like yours. Wonder why these through hole components come presoldered.... nevermind
According to my undesrtanding and to what ljm said earlier, an L25D with two 4020 is better suited to deliver power in 4ohms than a L15D with only one 4019.
I'll run mine at 60V. Will see how much power I can get out of them in 4ohms.
I am in the process of bying upgrade parts where appropriate.
- low esr filtering caps
- input 22u caps : nichicon muse or elna silmicII with a bypass capacitor
any other parts which could need an upgrade ?
thanks
Old 1st March 2012, 12:05 AM   #322
s3tup is offline s3tup
s3tup's Avatar
By the way, it is the easiest kit i ever soldered - all the component values are on PCB, you don't need to cross-check with BOM, and all these parts have largish PCB pads - easiest soldering ever.
Thanks LJM!
Old 1st March 2012, 02:38 AM   #323
JLesterP is online now JLesterP  Philippines
thanks
I see.. I also compared the datasheet of IRFI4019H and IRFB4020PBF, IRFB4020PBF definitely has better specs.
Old 1st March 2012, 10:28 PM   #324
The L25D kit comes with 6 x 22uF electrolytic capacitors per amplifier, rated 100V.
In the IRAUDAMP7S reference design BOM, the 22uF capacitors are rated 25V
Can I trust the BOM and use 25V rated 22uF capacitors ?
Old 2nd March 2012, 02:19 AM   #325
You can use higher voltage rating for capacitors
http://www.learningaboutelectronics....capacitor-mean
Old 2nd March 2012, 08:04 AM   #326
What does the Voltage Rating on a Capacitor Mean?
Of course higher rating is not a problem.
My question is about replacement of the kit 100V capacitors by better caps, 25V rated these are easier to find.
I'd like to use panasonic FC caps.
Old 3rd March 2012, 12:41 AM   #327
bukkehave is offline bukkehave  Denmark
Hi Maarten
Wow it looks awsome! I wanna bould one exactly like yours. I have looked around the net, but cant find the chassis - will you link to it?
I am also a little bit confused about witch powersupply u use - and why so large 800? Is it this one; Connexelectronic
What is the price in total?
Thanks in advance
Ps. can u make a higher resolution photo of the inside.?
Originally Posted by platenspeler View Post
With so much discussion going on on this forum, many of you must have finished the amp by now. Please post more pictures of your finished amp, I'll post some of mine to start with.
Amp modules: L20d
SMPS: Connexelectronic SMPS800R (2 x 60V dc)
Speaker Protection: Connexelectronic, powered by Aux 12Vdc of the SMPS
Chassis: Galaxy 230x280/80 with 10mm front (and alu covers)
Maarten
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 3rd March 2012, 08:31 PM   #328
Jolojl is offline Jolojl  Sweden
Hi!
I have two questions about The IRAUDAMP7.
1) The IRAUDAMP7 data sheet (http://www.irf.com/technical-info/re...iraudamp7d.pdf) mentions various AMP7D implementations, including one AMP7D-55 running on 25V. Is this just a matter of supplied voltage (i.e. can one run any of the AMP7D kits available on for instance 30V) or does this require a specific implementation?
2) What is the input impedance of the AMP7D? In the data sheet there is this phrase in the Input Signal and Gain Setting section that says "A proper input signal is an analog signal ranging from 20Hz to 20kHz with up to 3 VRMS amplitude with a source impedance of no more than 600 Ω.". This seems to imply a quite low input impedance (probably not more than 6K ...), does anybody know for sure?
Best!
Johan
Old 3rd March 2012, 09:09 PM   #329
MrSlim is offline MrSlim  Canada
If IR is suggesting 25V caps in their design, then you should be fine. It would be nice if you could build them with the supplied caps, get used to the sound and then make the cap changes, so you can see if you can identify an improvement.. (or even do one channel first and do some mono testing..) and report back to us.. ;=
Old 4th March 2012, 01:01 AM   #330
cwier60 is offline cwier60  United States
There's no problem running any of the higher power implementations at lower supply voltages and thus lower maximum output power, unless the undervoltage points have been set above this supply voltage. Sorry, but I haven't checked whether that is the case.
Looks like it's 3.3K, which is pretty low. It's R2 + R7. This gives a high-pass DC block at 2.2 Hz with the 22uF CP1.
My design L20D IRS2092+IRFI4020H  200W8RHide this!Advertise here!
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 30th April 2017 07:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 02:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 09:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 03:46 PM
Design help needed for IRS2092 cmhadley Class D 1 3rd January 2009 12:06 AM
Copyright ©1999-2017 diyAudio
