My design L20D IRS2092+IRFI4020H  200W8R
Old 21st November 2011, 11:54 AM   #251
MrSlim is offline MrSlim  Canada
Originally Posted by alkasar View Post
everyone knows that black painted amps sound better than silver ones
Like red cars: they are faster
Well, it's a matter of opinion, Black amps tend to have a darker sound.. and Sliver amps tend to be brighter..
Old 21st November 2011, 12:05 PM   #252
alkasar is offline alkasar  France
so Pinkmouse knows what to do fo his multichannel amp
Old 21st November 2011, 12:24 PM   #253
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Yup, black for bottom, a nice warm orangey-red for the mids, and a pearlescent white for that bright zingy top end.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 26th November 2011, 05:14 PM   #254
lithoc is offline lithoc  Malaysia
lithoc's Avatar
Hi LJM,
For L25D, is IRFB4020PBF can be replace by IRFB5620PBF ?
For the inductor, is there anything in between > 13A & < 31A ?
20A should nice without increase the price too much
IMHO, L25D should be more than 450W @ 4ohm.
Old 26th November 2011, 07:07 PM   #255
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
IRS2092 should be able to drive those with no problems. Of course, getting the OK from the designer is better than my opinion.
Old 1st December 2011, 01:33 PM   #256
ljm_ljm is offline ljm_ljm  China
Hi LJM,
Irfb4020 and IRFB5620 interchangeable.
Used for L25D. I suggest using IRFB4020.
The transistor usually power, the greater the current, his performance parameters are much lower.
Grid charge Qg influence is the loss of the key parameters MOSFET switch, lower Qg will lead to faster switch speed and a low grid of loss
IRFB5620 Have lower RDS. Can improve efficiency. Reduce the heat tube field effect.
But it may not be for a higher frequency.
Old 3rd December 2011, 08:14 AM   #257
alvinlim is offline alvinlim  Malaysia
LJM - I made a mistake in my power supply . It is +/- 52V. However, I have build up my L25D already. Can I use my existing power supply without changing the L25D? Thanks, Please let me know.
Old 4th December 2011, 12:24 PM   #258
luizcpimenta is offline luizcpimenta  Brazil
Originally Posted by ljm_ljm View Post
This is me a new design of the AMP. He had since the IR company demo version IRAUDAMP7S-200.
It USES the IRS2092 driver IC, and the IRFI4020H special mosfet output
Its power can do 200 W 8 R (+ 65 V). So I call it the L 20 D.
Hi Ljim.
I'm from Brazil.
Could you provide me with the layout of this amplifier?
I bought 02 of these plates by ebay and really enjoyed it.
Thank you.
Old 4th December 2011, 03:08 PM   #259
I know you said power supply.
IT IS AC 52-0-52 , OR AC37-0-37 Rectifier = DC + - 52 V?
if it is AC52-0-52, RECTIFIER =+ - 72V.
so It can not work in L15D.
it is can use L25D only.
Old 4th December 2011, 03:09 PM   #260
DC + - 52. can use L15D 。
My design L20D IRS2092+IRFI4020H  200W8RHide this!Advertise here!
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 30th April 2017 06:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright ©1999-2017 diyAudio
