My design L20D IRS2092+IRFI4020H  200W8R
Old 19th September 2011, 02:17 PM   #141
salvinci is offline salvinci  Italy
Originally Posted by ljm_ljm View Post
Very enough. You want to know how much you need to use the power output.
the power output is 150/200w max.
I am interessed an a hi-end sound quality, not a big power.
I use the totem pole tube 6sn7 preamplifier, i hope in big combination tube (old system) + class D (new system amplification).
Old 22nd September 2011, 04:34 PM   #142
rickedd46 is offline rickedd46  United States
LJM,
The 2K2/1W resistor next to the D669 gets very hot and changing color on both boards even at idle. What should I change? Remember I'm running +/-70V.
Old 22nd September 2011, 04:41 PM   #143
cOz is offline cOz  United States
Originally Posted by rickedd46 View Post
LJM,
Run less
Old 23rd September 2011, 03:26 AM   #144
Bernie7 is offline Bernie7  Singapore
Measured the L20D board for temp while music was playing using a DVM with thermocouple. I'm using linear supply +-63VDC and 4ohm rated speakers (speakers' impedance actually dip to 4ohms only at 100-150hz, most of the time they're above 6ohms for other frequencies).
Heatsink - 45degC
1.1K resistors (one of them beside LED) - 80degC
2.2K resistor (beside D669) - 100degC
This is with the chassis cover removed, and readings may go up another 10degC with cover in place.
Are these resistor temps too high, should higher wattage ones be used instead?
Old 23rd September 2011, 05:00 AM   #145
ljm_ljm is offline ljm_ljm  China
LJM,
B: yes, I also found this phenomenon, in some time ago I this a few resistance are replaced by 2 W power.
In the IRAUDAMP7S IR noted in 2K2/1 W apparently is not so correct, because the resistance the power consumption of the above about 1.3 W.
If you are some time before buying it, I suggest that you put the two resistance to change is 2 K2/2 W.
If no hav, please contact suppliers, I can send you a few.
Old 23rd September 2011, 08:01 AM   #146
Now I have resistance change for 2 W power, military quality metal oxide film type.
It has a small change in temperature.
Today some L20 D I start with speakers as a test.
+ 77 V 4 OHM. Good work and almost no temperature.
Old 23rd September 2011, 03:22 PM   #147
Thanks for responding. I will get some 2W ones and replace them.
Old 24th September 2011, 01:06 AM   #148
My 2.2k resistor is beginning to discolor after 1 day. Will be asking Zoe Tsang for a 2 watter as E14 doesn't carry this part.
Try changing the input DC blocking cap as well. Since my present sources are AC coupled, I shorted the input cap just to hear the difference. Significant gains - signal is just so much cleaner and less colored. Ymmv as some prefer the color of caps, in which case roll out your fave caps
Old 24th September 2011, 01:08 AM   #149
This 2 W resistance can also, just a little bit big volume.
Metal film resistors.
Old 26th September 2011, 01:39 PM   #150
My power supply outputs 56w. I assume that I can run L20D with no problems, correct?
My design L20D IRS2092+IRFI4020H  200W8RHide this!Advertise here!
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 35 30th April 2017 06:14 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 01:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 08:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 02:46 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Copyright ©1999-2017 diyAudio
