Go Back   Home > Forums > Amplifiers > Class D
Old 27th June 2011, 01:13 PM   #1
jtjy is offline jtjy  Singapore
Default Creating a Sub Signal out
Have a class D amp. How do i go about creating a sub signal out to my active subwoofer? Something like Nuforce amp with a sub signal out. Am using a tk2050 hifimediy
Old 27th June 2011, 03:08 PM   #2
Centvrion's Avatar
I can only direct you on the right way...then you have to ask somebody else because I have no time in these weeks..
Rough solution: connect L and R channels to the inverting pin of a high quality opamp, configured as buffer, then the opamp output to the amp. Virtual earth allows mixing channels without messing source signal.
Old 27th June 2011, 03:38 PM   #3
what if i have a b1 buffer already?
Old 27th June 2011, 06:25 PM   #4
Centvrion's Avatar
sorry but I made a mistake.
You have to put a high value (eg 50k) resistor before inverting terminal, one each channel....then u have to set a resistor on the feedback or it can goes in buffer configuration.
About B1...don't know, but it would be better a new device for this application.
hope someone else can help you, but this is the way, try googling.
Old 28th June 2011, 08:08 AM   #5
You can create a "line level" output after the power amp. I have a simple schematic somewhere.
Audio magus used to make a SUBLINE accessory to do this for t amps. Google it.
Regards.
Michael
Old 28th June 2011, 08:17 AM   #6
pinkmouse's Avatar
Here you go. You need Circuit 2 with just two inputs and one output.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 28th June 2011, 12:22 PM   #7
do u still have it? audiomagus is not producing any of those anymore.
Old 28th June 2011, 01:52 PM   #8
Like the Audio Magus product, you simply connect this circuit to the loudspeaker terminals.
Regards.
Michael
Old 28th June 2011, 02:16 PM   #9
alright thanks. so i have to make 2 of this to achieve a R and L line level output correct.
Old 28th June 2011, 02:38 PM   #10
Yes.
You wont need long interconnects though!
Regards.
Michael
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
Creating new PCB Contacts bazooka Parts 2 30th January 2005 10:45 PM
Creating a differential signal from a single-ended signal for bridged amps Peter Daniel Chip Amps 45 8th November 2004 12:47 PM
Creating a wiki Mr Teal Everything Else 3 25th October 2004 09:59 PM
Page generated in 0.09050 seconds (87.02% PHP - 12.98% MySQL) with 10 queries
