Creating a Sub Signal out
I can only direct you on the right way...then you have to ask somebody else because I have no time in these weeks..
Rough solution: connect L and R channels to the inverting pin of a high quality opamp, configured as buffer, then the opamp output to the amp. Virtual earth allows mixing channels without messing source signal.
what if i have a b1 buffer already?
sorry but I made a mistake.
You have to put a high value (eg 50k) resistor before inverting terminal, one each channel....then u have to set a resistor on the feedback or it can goes in buffer configuration.
About B1...don't know, but it would be better a new device for this application.
hope someone else can help you, but this is the way, try googling.
