Go Back   Home > Forums > Amplifiers > Class D
Old 23rd June 2011, 08:22 PM   #1
Default Alpine MRP-M1000 no sound
Ok i bought this amp off amazon i bench tested it and it worked unhooked it and fired it up four days later and now there is no sound and sounds like im going to be stuck making payments on a dead amp. when i hooked it up the second time i noticed the blue light flickering and the subs were making a popping noise with nothing hooked up to it. If someone has a service manual on this can i get it? thanks for any help.
Old 23rd June 2011, 11:11 PM   #2
nigelwright7557's Avatar
Check output MOSFETs first for shorts.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 23rd June 2011, 11:19 PM   #3
Pics of what I should test would be helpful
Old 23rd June 2011, 11:56 PM   #4
ok here is what i know. the amp must be shorting out somewhere when i try to do a bench test with the ATX power supply like i always do. once the amp turns on it makes the PSU power down. i am connecting with 12 volts 18 amps. If i connect it to a battery it stays on.
Old 24th June 2011, 12:52 AM   #5
You need to use a multimeter on the output transistors to see if any pins are shorted.
Old 24th June 2011, 10:57 PM   #6
This may be a dumb question but is it possible to fry the amp with a multimeter?
Old 26th June 2011, 04:06 AM   #7
i tested the amp again today on a battery the light stays solid and flickers when it does this it makes the subs pop. i did so testing with a multimeter and found that some transistors were going up to 20 volts at times.
Old 27th June 2011, 05:25 PM   #8
Im having the same problem but the light isnt flickering and im pretty sure i fried a transistor the pins look burnt i was wondering if anyone knew where to get transistors for this amp
alpine mrp-m1000 mike49504 Car Audio 45 16th October 2011 10:03 PM
Alpine MRP-M1000 mike49504 Car Audio 20 4th June 2011 03:37 AM
Alpine MRP-M1000 mike49504 Car Audio 7 30th January 2011 09:57 PM
No output from MRP-M1000 BlackCivicHatch Car Audio 24 2nd January 2011 03:10 AM
Alpine MRP-M1000 argonrepublic Car Audio 2 11th August 2009 02:28 PM
Page generated in 0.07022 seconds (86.09% PHP - 13.91% MySQL) with 10 queries
