Go Back   Home > Forums > Amplifiers > Class D
Old 21st June 2011, 05:42 PM   #1
Default rockford fosgate bd1500.1
hi all.firstly forgive me if i opened a new thread in the wrong place.please direct me here moderators.
now then.i got a rockford fosgate bd1500.1 from a friend that goes into protect when powered up.so i took it apart and found one fet reading short.its irf3415 i'm assuming this is in the output section.so i disconnect this fet from the board and tried startin the amp again.this time it draws excessive current from my power supply and blows the fuse.all the while its whining a lot too.i tried desoldering the red + black wire to isolate the amplifier section and it starts up ok idling at around 2 amps.also tested the transformer and its output is around 59 volts ac.
please lead me as to where else i must check now..
Old 22nd June 2011, 05:34 AM   #2
MOER is offline MOER  United States
Default ROCKFORD BD1500
Send me your email address and I shall send you the schems
Mine is zedaudio@aol.com
Steve
Old 23rd June 2011, 12:34 AM   #3
nigelwright7557's Avatar
Interesting it still draws too much current with the faulty FET removed.
Are you sure the other one hasnt gone as well ?
Or could be chip that has been wiped out with the FET?
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 23rd June 2011, 01:55 PM   #4
hi my addy is robin_22x@yahoo.com.
Old 23rd June 2011, 01:57 PM   #5
which chip do you refer to nigel?
Old 25th June 2011, 02:52 PM   #6
ok guys i pulled the outputs from this amp and all the current issues ect is sorted out but i still have the protect light on.any thoughts will be appreciated .
Old 2nd July 2011, 09:28 PM   #7
still waiting on the schemes moer....
Rockford BD1500 seankane Car Audio 19 1st June 2011 01:40 PM
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
rockford fosgate BD1500 stopped working NauTech Car Audio 290 25th May 2011 09:52 PM
Rockford Fosgate BD1500.1 mike49504 Car Audio 4 17th March 2011 10:39 PM
Rockford fosgate Bd1500.1 mike49504 Car Audio 25 21st September 2010 05:24 PM
Page generated in 0.08985 seconds (78.28% PHP - 21.72% MySQL) with 10 queries
