problem with hip4082
Old 21st June 2011, 11:54 AM   #1
chaitanya2k6er is offline chaitanya2k6er
Default problem with hip4082
hi every one, i am facing a problem in driving a full bridge of MOSFET's with HIP4082. The problem which i am facing is, ringing at the output of FET's (i.e after the output raising from 0 to 50V). I have used the IRLR120N mosfet's in the bridge with an input of 50v. I could be glad if some one helps me out to solve this problem. Please find the attached circuit diagram.
Thanks alot..
Old 21st June 2011, 03:26 PM   #2
ChocoHolic is offline ChocoHolic  Germany
The problem might not be the HIP, but...
Layout
Snubbering
Output choke
Search the forum, you will find lots of threads about issues with HF ringing.
Obviously you are not alone, because this is one of the key headaches for class D DIY and in the mean time there is enough information out there to get it right.
Old 21st June 2011, 08:34 PM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I use a t106-2 core with 2 meters of wire for my class d amp.
I tried power inductors but they just got too hot.
The pcb tracks need to be as short as possible and the circuit well decoupled.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
problem with hip4082Hide this!Advertise here!
A discrete class D with HIP4082 Joku Class D 7 31st May 2011 11:10 AM
Help with HIP4082 Peter_ma Class D 4 29th January 2005 07:35 PM
Copyright ©1999-2017 diyAudio
