SMPS problem
SMPS problem
Old 27th September 2003, 01:22 PM   #111
jackinnj is offline jackinnj  United States
jackinnj's Avatar
SMPS problem
I am still wondering if there is a reason you don't want to use the error amp in the SG3524 to control the pulse duration. You might as well just use a multivibrator like a '555 in this application if not.
Old 28th September 2003, 09:02 AM   #112
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Subwo1...
What maybe the reason for which if i connect a real load (a power amp for example) the voltage goes quicly down? From +/-42V to 0.5-1V???
I don't think that's normal...
Old 28th September 2003, 01:10 PM   #113
MaXiZ's Avatar
Ok explain me how i should modify my schematic to make this!
Old 28th September 2003, 02:53 PM   #114
IVX is offline IVX  Russian Federation
IVX's Avatar
actually maybe for Image6a.jpg R7=R8=R9=R10=0 & R5=R6=10 UP TO 100ohm.
Best regards,
E1.
Old 28th September 2003, 05:30 PM   #115
jackinnj's Avatar
SMPS problem
and perhaps you would like to use the current sense on the LM3524 next. At any rate, here's how to control the pulse width using the error amp.
voici:
Old 28th September 2003, 09:30 PM   #116
MaXiZ's Avatar
and what about this?
And 2.5V mean that i should regulate the trimer to have 2.5V ad pin1?
Old 29th September 2003, 05:04 AM   #117
subwo1 is offline subwo1  United States
subwo1's Avatar
What the 2.5V means is that is what you see there when the circuit is regulating correctly after adjusting the potentiometer jackinnj showed you in his circuit. You adjust the potentiometer to get the 37.5V on the B+ output.
The picture you just showed shows the current limit resistor and how it is used. It goes between the sources of the power mosfets and ground.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 29th September 2003, 05:47 AM   #118
IVX's Avatar
Hi all
if it's caraudio PS then GND primary & secondary must be "ISOLATED" & voltage feedback better be isolated too by opto device.
regards.
Best regards,
E1.
Old 29th September 2003, 04:29 PM   #119
MaXiZ's Avatar
Do u mean this?
R12 and A4N35 section?
OR what do u suggest to Isolate Primary GND and Secondary GND?
Old 30th September 2003, 04:31 AM   #120
IVX's Avatar
this design have 12vGND & 37v GND is ok.
Best regards,
E1.
SMPS problemHide this!Advertise here!
SMPS problem? choncba Car Audio 11 8th May 2008 07:54 AM
4kW SMPS RFI problem Disney_SK Power Supplies 30 10th September 2005 09:37 AM
What is the problem with the K6 SMPS? ghemink Power Supplies 2 16th March 2005 02:30 AM
Rod's SMPS Problem fr0st Parts 9 15th March 2003 06:46 AM
Copyright ©1999-2017 diyAudio
