Go Back   Home > Forums > Amplifiers > Class D
Old 16th June 2011, 03:44 PM   #1
Default Triac Before Transformer?
I'm building a power supply for a TDA8920 I got off ebay. I have a old toroidal tranny which is a PSU for an old 400W amp. It puts out two out of phase 40v and two out of phase 90v. This little amp wants max 30v so my thought is to put a motor controller or dimmer switch in front of the tranny to reduce those 40s to 25s. The PSU has a couple fat caps on there. Is that a viable plan?
Old 16th June 2011, 07:34 PM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
It might work. Can't suggest it.
Dimmer switches don't work by lowering voltage, they do so by cutting out part of the AC cycle. Technically, if you dim below 50% duty cycle at the triac, you'll start cutting the peak voltage down a bit and the rectified output of the toroid will drop.
But the result is sharp DV/DT out of the dimmer switch and into the transformer when the triac fires, which combined with the low leakage of the toroid, could cause damage to the dimmer switch, your amp's rectifiers, output capacitors, etc.
And blowing up the dimmer switch wouldn't be good - if it fails short-circuit so you get 40V into your amp, you've got problems. Heck, if any of the above fail, it won't be good.
Even if it works, the sharp DV/DT might put an awfully bad 100/120Hz+harmonics buzz on the output of your amp.
Either use a variac, buy a different transformer... or if you're lucky and the 40V windings were the last ones wound on the toroid, you might be able to remove some windings and get the voltage down.
Old 16th June 2011, 08:20 PM   #3
I had considered unwrapping some of the secondary, but preferred an easy way out.
Maybe I should investigate using a pair of Radio Shack LM317T? They deliver 1.5A each, which at 25V gives 75W, plenty for this application. Maybe I could use them to drop 15V and deliver DC straight to the secondary side of the bridge. I'll have to look.
Old 16th June 2011, 08:38 PM   #4
nigelwright7557's Avatar
Just buy the right transformer, anything else will just generate a lot of heat.
Its difficult to drop volts at that current without geneating a lot of heat.
Only other option is a SMPS.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
triac replacing transformer is it possible???????????? phoenix87 Power Supplies 3 5th July 2010 09:28 AM
Need a Triac zedrider Parts 1 28th September 2007 03:38 PM
SCR or TRIAC? Wombat2 Parts 3 6th June 2006 03:21 AM
Triac regulator fr0st Parts 2 19th November 2004 06:15 AM
Triac Question vinay Pass Labs 8 26th August 2003 08:31 PM
Page generated in 0.07388 seconds (73.22% PHP - 26.78% MySQL) with 10 queries
