Go Back   Home > Forums > Amplifiers > Class D
Old 13th June 2011, 09:06 PM   #1
Default Schematic Check Please: TPA3016D1
Hi this is a schematic for my TPA3016D1 build. Any comments are welcome.
-I am planning to connect the signal and analogue ground under the chip on the power pad as recommended.
-All of the power caps which are >1uF are electrolytic (should I be looking for a special type?)
-All caps <1uF are X7R low ESR ceramic caps
-I dont know what to use for the output inductor (33 mH with ~1.7 A through it). Someone gave me a recommendation to wind my own for high current but 1.7A is quite low. I would like to use surface mount if anyone has recommendations.
-I chose to have a fault turn the chip off and didn't connect fault to mute (which restarts the chip).
-It mentioned that I should 'shutdown' the chip first before powering off to avoid a "pop". I didn't know how big of a deal this was so I ignored it.
Old 13th June 2011, 09:45 PM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
I'd add a low value (10 ohm) resistor between the audio input ground and the board ground.
Also, I'd suggest just using a single ground plane for everything.
Old 14th June 2011, 09:06 AM   #3
INN have to grounded otherwise you will get big common noise .
c? = 2.2uF between INP and INN is too big , for simple tone adjust you can add 15nF CAP here.
Old 15th June 2011, 04:06 PM   #4
the data sheet recommended having seperate ground planes and connecting them under the chip for some reason. (if anyone knows why that would make sense please tell me)
So i would have two 1Kohm resistors on the stereo to mono inputs of my audio in and a 10 ohm resistor from audio in ground to signal ground or power ground?
That is true, based on the 32Kohm input impedance I could use a 22nF cap to have a 200 Hz high pass (I will have a number of caps since i dont know exactly where to cut the lows)
Again i suppose i should have a 15nF cap or so on the low pass to cutoff around 20kHz
Need help to check out this preamp schematic. pchw Tubes / Valves 7 27th December 2007 07:47 PM
Schematic for check Jean-Paul_2 Everything Else 1 20th May 2007 01:02 AM
Prof-check this schematic (Please!!!!!) ifrythings Power Supplies 5 14th September 2006 02:22 AM
Check this schematic please CJ900RR Chip Amps 19 6th August 2006 09:34 PM
Check the schematic please... captain Chip Amps 0 28th November 2004 02:24 AM
Page generated in 0.10156 seconds (75.90% PHP - 24.10% MySQL) with 11 queries
