| Class D Switching Power Amplifiers and Power D/A conversion |
I'd like to have a go at putting together my own t-amp using the kits from Arjen Helder.
I've never done an electronics project of any kind (but I'm pretty handy generally and a quick study!). Can anybody recommend a good book or website to give me tips about how to go about putting one of these into a case. Also where can I source appropriate cases for these units? Finally, what kit am I going to need? Here are the two products I'm interested in. NEW tube pre-amp MKIII 12AU7 fully assembled | eBay New MKIII Tripath TA2020 PCB 25watt Class-T amplifier | eBay Many thanks in advance - any advice welcomed. Charlie |
#2 |
You really just need to understand how to wire it up.
You obviously need a power supply for the pre amp and amplifier. The only problem you might come across is poor earthing causing hum and this is usually sorted by using a single point ground for all ground lines.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| Advice Needed | grungeman91 | Tubes / Valves | 2 | 19th March 2011 08:26 PM |
| First timer build - Advice | nightanole | Chipamp | 0 | 8th January 2010 06:37 PM |
| Help/advice needed | jjs4028 | Multi-Way | 13 | 11th October 2006 10:16 PM |
| Need Advice with Timer Relay Shut Off | Bryan | Tubes / Valves | 7 | 25th October 2005 07:43 PM |
| Quick Relay/Timer Help Needed | woodrufj | Parts | 3 | 24th June 2004 06:05 PM |
| Page generated in 0.07898 seconds (75.47% PHP - 24.53% MySQL) with 10 queries |
