Go Back   Home > Forums > Amplifiers > Class D
Old 8th June 2011, 12:48 AM   #1
nonprof is offline nonprof  United States
Default JLHD750/1 sounds growls very loud!!!
Hello! Im just newbie here...thanks I found this forum!
Can you please help me to determine what is the exact problem of my JL amp, it growls very loud and IRF 7225 output transistors keeps heating...Ive checked the transistors but is OKs, I replaced IR2010 drivers but no changes...replaced the biased capacitors and diodes for IC drivers but still no changes...Im now on dead end...Please help I spent to much here...and cant afford to buy a new one..this is very expensive in our country Philippines.
Note: This amp had gone major repair on power supply side...dont know If i have noisy power supply.
thanks in advance!!!!
Old 8th June 2011, 12:52 AM   #2
nigelwright7557's Avatar
You could measure the power supply voltages and see if they are in spec.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 8th June 2011, 02:22 AM   #3
I think the +VDD rail supply is slightly high...it measure 110VDC...I'll check it again what's on spec. do you think if I have 10VDC higher it will cause a growling output? thanks to your reply...
Old 8th June 2011, 05:49 AM   #4
MOER is offline MOER  United States
Default HD750
The power supply to the main class D FETs is +90v DC
If it is higher your main switch mode supply regulator is bad due to incorrect feedback
Steve
Zed Audio
Old 8th June 2011, 06:13 AM   #5
Steve
Zed Audio
Do you have an idea where I can start isolating the problem on switch mode regulator? I will be having difficulty on finding the problem, im not excellent on electronics. I can send JLHD750 main schematic if you want...
Yet another loud GhettoBlaster willek Everything Else 29 7th May 2012 10:14 AM
Ultrasonic - how loud is too loud? wwenze Everything Else 1 9th November 2010 10:20 AM
For those that like it loud RacerXtreme Multi-Way 25 12th September 2007 04:02 AM
How loud can you go? paulspencer Multi-Way 7 28th June 2007 04:12 AM
how loud do i need to go badger Multi-Way 6 8th January 2002 07:24 PM
Page generated in 0.08602 seconds (71.97% PHP - 28.03% MySQL) with 10 queries
