Hypex Ncore
Hypex Ncore
Closed Thread
Old 22nd December 2011, 01:03 PM   #981
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
Originally Posted by Julf View Post
So here in Amsterdam I should scale the supply voltage down to 50V or so (I am forever changing light bulbs, as the old supply network from the 50's is less than stable but nothing gets replaced until it blows up)
Offtopic:
My dad had this issue at his office som eyears ago. A UPS kept throwing some servers down at night, turned out the voltage dropped so much the UPS tripped and safely shut down the servers. The net-guys actually monitored voltage for a full three weeks before they decided to dig new cables in to the main distribution point.
Right. Back on topic ...
Si fractum non sit, noli id reficere!
Old 22nd December 2011, 05:26 PM   #982
StigErik is offline StigErik  Norway
StigErik's Avatar
Ontopic:
I've noticed an other very nice side of the Ncore's sound (or lack thereof)...
There are lots of recordings that are not polished to sound pretty on everything (like most so-called "audiophile" recordings are). In other words, a lot of recordings may sound harsh, "shouting" or grainy. But wait... the Ncore's fabulous resolution manages to dissolve such recordings into its real content instead of just presenting it as one big lump of dirt.
I guarantee you that some will complain about this, mistaking midrange "shout" for dynamics. Which is utterly wrong of course.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 22nd December 2011, 05:51 PM   #983
RockLeeEV is offline RockLeeEV  Canada
Originally Posted by Bruno Putzeys View Post
Zaph Audio tested a few B&G units and considers them the only good ribbons (seriously good at that).
Zaph has never tested a 140-15d or 70-20XR
Old 22nd December 2011, 06:02 PM   #984
pieter t is offline pieter t  Netherlands
Beyma AMT as dipole sounds great; does not need raw amounts of class d power.....
Old 22nd December 2011, 06:13 PM   #985
StigErik's Avatar
True. I've used it as dipole, and its really good. But I like the RD-75 more...
Old 22nd December 2011, 08:26 PM   #986
Yves Smolders is offline Yves Smolders  Belgium
Guys, sorry if I missed it browsing through the pages...
...but is there still any form of opamps on the ncore?
As I'm upgrading B&W 804S to the latest B&W 802 Diamonds, I might also get Ncore amps just to be 'sure'. My 'preamp' is a W4S DAC2.
On a sidenote, I did test my DIY amp (straightforward dual mono UCD400HG/SMPS400) on said 802 diamonds, right after listening to them on a devialet amp (hybrid AD) - they come pretty close to the devialet and had absolutely no problem driving those speakers LOUD. They were driven straight from an accuphase SACD player with variable XLR output.
Thx!
Old 22nd December 2011, 08:30 PM   #987
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
discrete opamp(s?) only.
UCD400HG vs. Devialet?
we all love a good ol' stereotype until it's against us
Old 22nd December 2011, 09:46 PM   #988
Omholt is offline Omholt  Norway
Omholt's Avatar
Hypex Ncore
Originally Posted by StigErik View Post
Ontopic:
So you don't experience some of the opposite; That bad recordings start to sound even harsher and more grainy due to more transparency?
Old 22nd December 2011, 10:01 PM   #989
Bruno Putzeys is offline Bruno Putzeys  Europe
That sort of thing commonly happens on replay systems which try to "sound transparent". It's a bit of a terminology thing. Some people use the word to mean "you get a barrage of details thrown at you", others use it to say "can't hear it do anything to the sound at all".
The first kind of "transparency" is actually a euphonic wow-effect which you can create by dipping the frequency response a dB or two in two places (600Hz and 2kHz) and optionally adding a small bit of HF distortion in the electronics (e.g. using all power FETs and no feedback). That produces what reviewers would describe as "startling clarity" and indeed such a system tends to overemphasize some of the things that bad recordings do badly.
But in the latter case (true transparency), when a recording sounds mucky, you only get the exact amount of muck that was in the recording, not artificially enlarged by the magnifying glass of an overzealous loudspeaker.
I knew all of this in theory until recently when the pieces in my active speaker design really started to fall into place. I now know it in practice too These days I can listen to literally anything on my main system. I no longer need a ghetto blaster on the side to listen to second rate stuff and make it listenable. I hear precisely what the recording does wrong but it doesn't keep unnecessarily drawing my attention to it. I can just get on with the music.
There's a time for everything, and this is not it.
Old 22nd December 2011, 10:49 PM   #990
john dozier is offline john dozier  United States
john dozier's Avatar
I experienced the exact same phenomenon when I changed to a new dac (Anedio). I found that even previously unlistenble cds were now enjoyable. I agree completely with Bruno's analysis. BTW, I currently use tube amps and VERY flat speakers. Regards
Evil looms. Cowboy up. Kill it. Get Paid.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
