Hypex Ncore
Hypex Ncore
Closed Thread
Old 29th December 2013, 05:50 PM   #7401
Julf is offline Julf  Europe
Originally Posted by markusA View Post
The signal is currently floating and referenced to signal ground as per the power-amp.
It can't be both "floating" and "referenced to signal ground" at the same time.
A differential input is just that - differential. So the signal is based on the difference between the inputs, and is *not* referenced to ground in any way.
If by "power-amp" you mean the nc400, it does not reference the inputs to ground.
Viewing the differential of hot and cold I get 3.3V at full swing I.e. 3.3V peak.
No, that would be peak-to-peak, not peak.
(Hot +1.65V and cold -1.65V)
Again, they are not referenced to some halfway point.
Old 29th December 2013, 06:07 PM   #7402
markusA is offline markusA  Sweden
markusA's Avatar
It might be that my terminology is totally off but regardless of that. Right now I have a transformer output. The transformer input sees a 1.65V bias to both hot and cold. When the hot peaks it'll hit 3.3V and at the same time the cold will be at 0V. On the transformer output the difference between hot and cold will be 3.3V.
(My old amps were single ended and I used a Xlr to RCA cable to take care of that. )
Is that considered 2.3Vrms or 1.15Vrms now that we're talking balanced connection?
Current build to be found in my blog. Not so current anymore, everything is put on hold until march.
Old 29th December 2013, 06:23 PM   #7403
The only thing that matters is "the difference between hot and cold will be 3.3V" part. That means that your signal is 3.3 V peak-to-peak, or 1.65 V peak, corresponding to 1.17 V rms for a sine wave.
I am not sure it is just a confusion of terminology - I am not sure you understand the fundamental principle of a differential input. The output of your transformer doesn't "know" one of the inputs is connected to ground - it just sees a voltage between the transformer output pins. Measuring just one of those pins against ground doesn't produce any meaningful result.
Old 29th December 2013, 06:32 PM   #7404
markusA's Avatar
Ah, gotcha. It's been a while since I was messing around with this stuff and I needed a refresher.
I did confuse things but now I get it. Looks like I'll rewire for twice the output voltage later on depending on if I need it or not.
Old 12th January 2014, 03:18 PM   #7405
fbee is offline fbee  Germany
Default ncore subsonic observation
Just made an observation, while having ncores amplifying L channels woofer and another amp doing the amplification for the R woofer (no Crossovers between amps and drivers) The side with the ncore showed a much more pronounced membrane movement (membrane control?), when feeding with a 2Hz sine wave. I swapped amps and speakers to exclude gain/source imbalances. The side with ncore always stayed the one with the much more pronounced membrane movement. Does this ncore (much more dynamic) subsonic behaviour point towards a more dynamic behaviour in the audible range? Or is it rather a nonsense observation?
Old 12th January 2014, 03:21 PM   #7406
fpitas is offline fpitas  United States
I'd guess it's because the NCORE low frequency response goes down to DC, and most other amps don't.
Francis
Old 12th January 2014, 03:27 PM   #7407
Careful - that sounds like a good way to destroy your woofer.
Yes, the ncore, being DC-coupled, can reproduce the 2 Hz, while most other amps probably won't - but the speaker might not be designed to take any significant energy that low in frequency.
Old 12th January 2014, 03:29 PM   #7408
barrows is offline barrows
Does the other amp have capacitor coupling at its input for DC protection? If so, it may be attenuating signals as low as 2 Hz.
Old 17th January 2014, 08:58 AM   #7409
The comparison was UCD400
AFAIK UCDs internal input stage terminates with 10uF
Nevertheless, the movements of the cone with ncore stay (optically) more intensive when the frequency is raised to 5,10,15,20Hz
Old 18th February 2014, 08:24 PM   #7410
jkess114 is offline jkess114  United States
Looking to sell my Ncore 400 dual amps. 1 SMPS and 2 Ncores per box for biamping. 800 per side. Thanks!
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 07:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 07:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 11:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 05:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 10:08 PM
Copyright ©1999-2017 diyAudio
