Hypex Ncore
Hypex Ncore
Closed Thread
Old 18th November 2013, 03:26 PM   #7251
fpitas is offline fpitas  United States
An observation on the "lack of reverb" or "too fast decay" issue. We replaced a class AB amp with a UcD400, and observed that the bass seemed reduced, and much "tighter" (less overhang). Using a microphone to compare frequency responses, it turned out the class AB amp driving the speakers had ripples in the frequency response where the driver impedance had ripples, whereas the UcD400 response was smooth. So the point here is to use a microphone and compare frequency responses of your speakers with each amp before coming to any conclusions. Ripples in the frequency response will lead to some degree of ringing at each peak.
Francis
Old 18th November 2013, 03:35 PM   #7252
Julf is offline Julf  Europe
Originally Posted by miero View Post
Julf: what about NCore switching frequency that might somehow physically influence a tweeter?
How, in your opinion, would the tweeter be influenced, and how would it reduce perceived reverberation?
Old 18th November 2013, 03:42 PM   #7253
Originally Posted by ghemml View Post
Professional and sophisticated tools are still based on DAC and ADC which still have its own distortion even for a Agilent X-Series
Of course any measurement system will have its own distortion. That is why it is so important to make sure you are measuring real effects.
I not very hard up on super accuracy, but even if the measurement contain distortion from DAC or ADC and the accuracy still can be obtained within +0.005% ~ +0.008%, which I view it as acceptable.
Right. And as those values are several orders of magnitude lower than your typical speaker (not to mention vinyl pick-up), they don't really tell anything about audible sound quality any more. All they do is they verify that the amps work as designed and within the manufacturers specifications.
Old 18th November 2013, 03:50 PM   #7254
Maybe the point is to realize that what we prefer has very little to do with objective, measurable fidelity. Some of us like tube-based vinyl rigs that have absolutely horrible specifications from an engineers point of view, and there is of course nothing wrong with that, as long as we don't start claiming that the vinyl rig has "better sound quality" in some absolute, objective sense.
The nc400 has extremely good measurable, objective performance. That might not be everyone's cup of tea.
Old 18th November 2013, 04:06 PM   #7255
Yes, you're right. I'm just making the point that when comparing performance, it's very helpful to verify sonic differences by measurement, even if the lower fidelity version is a personal preference.
Francis
Old 18th November 2013, 04:08 PM   #7256
I agree. But the measurements I have seen pretty much confirm the specs published by hypex.
Old 18th November 2013, 04:10 PM   #7257
barrows is offline barrows
Julf: respectfully, these are pretty funny statements coming from you. First of all, the idea you propose that additional low order harmonic distortion (such as with a tube amp, or certain class a SS amps) results in a euphonic "warm" sound has never been proven at all. In fact, in blind tests done by Stereophile, this myth was was dis proven. But you seem comfortable speculating that any time someone prefers a different amp to the Ncore, that the preference must be because of a fault (coloration) of the other amp.
Further, it is only speculation to assume that some people prefer the sound of certain tube amps because of the faults (coloration), this is unproven as well. It could easily be that some people actually prefer the sound of certain tube amps because they are actually more accurate than (Ncore) in certain areas of performance which standard measurements do not illustrate (despite higher noise/THD).
I think, to be consistent with your POV that science should be used to evaulate performance, that you should probably not be speculating about these things, and making these assumptions.
Really, there are some very, very smart folks here at DIYaudio. I think it is time that some of these really smart folks start working at ways to improve how we measure amplifier performance. It is more than clear to me that steady state signal tests, and the occasional 10 kHz square wave are entirely inadequate to describe the differences in sonic results of different amplifiers. I suspect that there is some area of measurable performance where the Ncore actually has problems, it is just a matter of finding the right way to measure for those problems.
It is time for someone to come up with some new paradigms in measurement, which really test time domain perfromance with highly complex mixed signals approximating complex music.
I love some of the things the Ncore does (low noise, microscopic detail retrieval) but acknowledge that it also seems to be missing some of the musical picture, and I do not think what is missing is 2nd order harmonic.
Old 18th November 2013, 04:14 PM   #7258
Good luck. Please keep us up to date with your progress.
Old 18th November 2013, 04:21 PM   #7259
Except Hypex can't tell you how your particular speaker will interact, and sound with their amp. In our case the tighter bass was desirable, but I suppose some people may prefer the looser version.
Francis
Old 18th November 2013, 04:21 PM   #7260
Default Yes..
Hahaha! I know what you mean, and I have neither the education, nor the equipment to even consider this development. I only recognize that we clearly do not know how to adequately measure amplifiers for all aspects of sonic performance (or at least, perhaps someone does, but that approach is not in common use).
We see many amplifiers wich exhibit meausured performance with "faults" which are far below accepted levels of audability; according to science, if these measurements were all that mattered, all of these amps should sound the same... clearly they do not though.
So, if we accept that these differences in sound quality exist, we have only two choices: accept that we evalauate the sound quality through subjective listening tests, or, endeavor to develop measurements which can actually describe these differences. There just seems to me a problem with suggesting that differences in sonic performance should just be blindly attributed to a +/- .0x% THD product alone.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 07:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 07:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 11:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 05:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 10:08 PM
