Hypex Ncore
Hypex Ncore
Closed Thread
Old 20th July 2013, 03:16 PM   #6991
Julf is offline Julf  Europe
Originally Posted by judderod View Post
If I run an additional connection between J1:5 of each amp, I'll create 'triangle' grounding (if there is such a thing).
So don't!
Since the standby current is so low, and there should only be current flowing when the amps are on standby, are we saying its OK to strap 0v of the standby psu to ground of the source? That way the return path for the standby current is the shield of the single ended cable. Then I connect J1:1 of each amp together with a single wire, which is connected in the middle to an SPST relay that switches the +v standby signal?
Is your standby psu grounded? If so, your 0v is already connected to ground, and no additional ground connection is needed. If not, connect 0 v to J1:5 to *one* amp, still no ground loop.
Old 25th July 2013, 10:27 PM   #6992
miero is offline miero  Czech Republic
I'm trying to find information about a settling time for NCore, but it is not mentioned in official materials or this thread.
I've found a requirement that it "must be less than 1Ás (microsecond), to maintain high quality audio" -- KV2 Audio
Have anyone tried to measure settling time for NCore?
EDIT: I've found something in AES118BP whitepaper from 2005 at page 5 suggesting it might be around 20us, but this is old paper and NCore might be different.
Old 25th July 2013, 10:43 PM   #6993
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
to my best knowledge, no independent measurements of NCOREs are available as of yet. Bruno does not believe in the relevance of square-wave response. FWIF I don't either.
that webpage kind of reminds me of those "a very well hidded secret about weight loss" ads.
and remember that there's a 400kHz carrier always riding on your signal, kind of makes you wonder about the relevance of 1us settling times. the FR plot of the NCORE (the small post 20kHz bump) indicates that there is some ringing, if that helps you in any way.
I'd stay away from webpages telling you that the response to something that never actually exists in music is relevant, but that's just me and my opinion.
we all love a good ol' stereotype until it's against us
Old 25th July 2013, 11:24 PM   #6994
I've found two reviews from USA Tour of NC400 that suggest there might be a problem with shortened/blurred decays of instruments:
- "Its almost like the Ncore sound is too fast and leaves the stage before the notes have time to 'shimmer' away in the distance. I feel as though the Ncore shortens the decay time of the instruments, resulting in a slightly smaller music space."
- " That said, and despite other things the Ncore does well, I find its presentation a little flat, and leaves me wanting more. It's as if the Ncore, like you said, drops the finer leading edges of the music---almost as if I'm listening through a cloth that veils high frequency decay, ambiance and subtle detail."
Source: Hypex NCore NC400 - USA Tour Listening Impressions
Old 25th July 2013, 11:38 PM   #6995
I think you are trying to relate two things which aren't so. I have no reason to believe that a shortened decay correlates with settling time, it's just an "antropomorphic" way to view things. IMO that could be a matter of frequency response and/or distortion. also, that is a stranger's opinion which might be just personal preference. you'll only know if you listen to it yourself.
one more thing. at some point I think that Bruno said something along the lines of being reluctant to post square wave plots because they are often misiterpreted. we should all remember 2 things. first is that you can make a very simple circuit with 2 passive components (I'll leave you to guess what it's called) which displays a "ringing" behavior in response to square wave signals, but manages to pass sines completely unaltered. second is that as long as you're feeding the amp the output of a CD player, the "worst" thing that it will ever output is a peak-to-peak 22.05kHz sine. so maybe it's better to look at an amp's behavior in response to something that resembles what your CD player outputs when it's not malfunctioning (and that is not fast-slewing sines).
Old 26th July 2013, 12:32 AM   #6996
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
IMO what's being reported there has nothing to do with settling time. Its modulation noise - the leading edge softening effect is the same as given by analogue tape to the abrupt percussive sound of a firmly struck piano key.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 26th July 2013, 12:46 AM   #6997
fas42 is offline fas42  Australia
Banned
This is a classic distortion artifact, often associated with digital reproduction. It may be hard to track down the precise cause and effect, but is most certainly something in the overall reproduction system that is misbehaving ...
Old 26th July 2013, 12:53 AM   #6998
abraxalito's Avatar
The symptoms do rather sound like power supply noise is creeping in. I'd suggest making a recording of the power supply noise while playing out music as I've done here: Possibly the most frugal high-end sounding amp? - Page 3
Old 26th July 2013, 05:16 AM   #6999
You might have noted that there is a specific section in the nc400 datasheet with "frequently asked numbers" that don't influence sound quality directly...
Old 26th July 2013, 06:20 AM   #7000
regarding the low settling time ... it might be important for playing DSD(SACD) ... and maybe for HD PCM too, e.g. 176.4kHz
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
