Hypex Ncore
Hypex Ncore
Closed Thread
Old 5th December 2011, 08:31 PM   #691
adelias is offline adelias  Greece
No offense but bridged nCores for a speaker of this caliber isn't wise economically IMHO, better off ditching the speakers and building something else.
Old 5th December 2011, 08:37 PM   #692
back is offline back  Greece
Originally Posted by Juhleren View Post
back,
I deliberately said sensitivity and not efficiency. But yes peaks in the area of 1600W (70V@3R) is only translated into acoustic output with an efficiency about 84 (if the speaker was 4ohm, which it isnīt) so we are really talking about 83dB if we are arguing over a trifle here :-)
A 1000W peak should still give you 113dB peak. If not your speakers are probably compressing due to heating of VCs and motor systems.
If you find the UCD2k with more grunt and worse distortion to sound better than the UCD700, isnīt the nCore the wrong way to go as it has both way lower distortion and lower power specs too?
If the nCore is happy with 1,5R loads you may find them usable in a bridged config, but remember that also nCore like UCDs seem to perform lower distortion at higher impedances hence you may not achieve much by bridging into so low impedances...
Hmmm, its probably wisest to go with Brunoīs advise here as your speakers seems out of the ordinary and very very different from what i have experience with...
cheers,
113db is the max they can give with ucd2k.
if i try more the woofers exceed their xmax.
ucd700 sound better than ucd2k except bass and very loud levels.
Old 5th December 2011, 08:41 PM   #693
Juhleren is offline Juhleren  Denmark
OK back,
That makes more sense.
Your speakers seem to power compress a great bit unless your ucd700īs are under supplied...
but frankly, most speakers would compress at those magnitudes of power, therefore much better to go light and fast IMHO
Old 5th December 2011, 08:42 PM   #694
it would take a lot of money to build something better which i can`t afford for now.
Old 5th December 2011, 08:46 PM   #695
OK back,
even PA speakers compress when they work at their maximum.
Old 5th December 2011, 09:30 PM   #696
Which is the same as saying that more power wonīt really help you much then....
Old 5th December 2011, 09:51 PM   #697
i don`t understand why we continue this conversation.
i don`t need more power i have plenty.
i need ncore with the same power but they will not be available.
if i can afford 4 nc400 i will buy them.
if not i will keep what i have.
after a couple of years (if i will still have a job)i will build something from
scratch and it will be fully active.
Old 7th December 2011, 09:10 AM   #698
TheShaman is offline TheShaman  Europe
Since I already know I will be building a pair of nCores, do we have exact dimensions for the amp and matching SMPS modules?
Old 7th December 2011, 09:51 AM   #699
phase_accurate is offline phase_accurate
it`s something like a passive linkwitz transform.
It is called a Watkins woofer BTW.
Charles
Old 7th December 2011, 10:39 PM   #700
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
Hypex, mail is crowded during holidays, Santa is going to disappoint a lot of DIYers if you get my point...
we all love a good ol' stereotype until it's against us
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
