Hypex Ncore
Hypex Ncore
Closed Thread
Old 11th July 2013, 12:14 PM   #6981
judderod is offline judderod  United Kingdom
Phew! Thanks so much. I'll get the soldering station now
Old 19th July 2013, 08:27 AM   #6982
After many hours of listing I'm pleased to say Hypex have another very satisfied customer. They really are all they're cracked up to be!
On first listening I found something lacking in the bass power and control. So I swapped out the 3 fairly thin solid silver/gold plated wires per binding post that were used initially to some very thick Chord Odyssey which is silver plated OFC. I was stunned to hear so much difference from changing just 3cm of wire. As mentioned previously on this thread, the ncore does seem sensitive to its output wiring.
I want to set mine up with a +12v trigger as posted a on here a while ago. As discussed I might have to make a basic transformer, BR & relay box to switch over my control output from +12v when on, to +12v when off to keep the SMPS in standby.
But did anyone ever find out if the SMPS has a constant output that could be used or adapted to keep it in standby?
Old 19th July 2013, 10:10 AM   #6983
Julf is offline Julf  Europe
Good to hear!
The ncores do benefit from low-impedance, high-current speaker cables - the less "audiophile magic" the better, it seems
Yes - the answer is "no". When the SMPS goes into standby, it really goes into standby. No voltages available.
Old 19th July 2013, 02:01 PM   #6984
OK thanks. Looking at the datasheet, to put the SMPS into standby; I need to apply +3.3 to 12Vdc to J1:1.
But I'm not sure where to connect 0v?
Maybe J1:5?
Old 19th July 2013, 02:16 PM   #6985
Maybe J1:5?
Yes, J1:5.
Old 19th July 2013, 04:16 PM   #6986
Great. So to avoid having an additional ground loop between the 2 SMPS's, I'm thinking it would be best to use two double pole relays, one for each. Or is that a bit overkill?
Old 19th July 2013, 04:51 PM   #6987
So your grounds wouldn't connect anywhere else? As long as there is some connection somewhere, you are OK using a single pole relay, as the standby signal doesn't cause any significant ground current.
Old 19th July 2013, 05:02 PM   #6988
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
The SPMSs are earthed to the case through one of the stand-offs
Each SMPS is earthed to the nC400
The nc400 is earthed to the case through the heatsink (IIRC)
The nc400 is earthed to the case via the xlr input
Old 19th July 2013, 05:08 PM   #6989
Right - that is the usual case, and with that setup, a single-throw relay is enough.
Old 20th July 2013, 02:16 PM   #6990
Yes I'm using the recommended ground wiring but with a single ended cable to each amp so the shield carries all ground currents to the source which is mains grounded. If I run an additional connection between J1:5 of each amp, I'll create 'triangle' grounding (if there is such a thing).
Since the standby current is so low, and there should only be current flowing when the amps are on standby, are we saying its OK to strap 0v of the standby psu to ground of the source? That way the return path for the standby current is the shield of the single ended cable. Then I connect J1:1 of each amp together with a single wire, which is connected in the middle to an SPST relay that switches the +v standby signal?
Sorry if I'm over thinking this but I'd hate to spoil the audio performance through lack of knowledge!
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
