Hypex Ncore - Page 696 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Closed Thread
Old 22nd June 2013, 06:32 PM   #6951
Originally Posted by Speedskater View Post
No, you can never wye two outputs into one input (neither balanced or unbalanced) the first output will see the second output as a dead short. You will need some sort of a switching arrangement or summing network.
RaneNote "Why Not Wye? "
Why Not Wye?
He isn't summing the input signals, he just wants multiple inputs (for what reason, who knows?) and will only use one at a time.
Old 22nd June 2013, 07:03 PM   #6952
ryfa is offline ryfa  United States
Yes, that is correct.
The reason has to do with my last attempt to keep a video system tied in with my two channel stereo. I have gravitated to a DAC (PS Audio PWD mk2) direct to amplifier configuration for two channel listening. I like it enough that I don't want to have to insert a pre-amplifier back into the chain. But that leaves me with the front left and right outputs of a home theater processor that I have to get into the amp. Without two inputs on the amp, I would have to resort to plugging and unplugging cables which is a pain.
Believe me, in the back of my mind I'd just like to separate the two systems altogether, however, I have limited space outside of the dedicated, and tuned room they are currently located in.
So, having two inputs on the amp would be huge... would have built the ncores long ago if I felt comfortable doing this.
Hope that sheds light as to the why.
Old 22nd June 2013, 07:06 PM   #6953
Speedskater's Avatar
But he will have to deal with the unused source. You can't just turn it off or hit the 'stop' button. You need a selector switch or a network. (well you could unplug one of the signal cables)
Kevin
Old 22nd June 2013, 07:11 PM   #6954
That was my assumption.
Old 22nd June 2013, 11:09 PM   #6955
OllBoll is offline OllBoll  Sweden
Shouldn't it be possible to sum the signals by putting a small resistor, say 10k on each of the balanced leads on the two input signals and then combine the two + signals and the two - and then connect the combined + and - to the NCore?
Old 22nd June 2013, 11:16 PM   #6956
He...doesn't.....want....to.....sum.....the signals!!!!
Old 22nd June 2013, 11:22 PM   #6957
Yeah, but if the signals are summed then he truly has multiple inputs... and just because he could play both signals simultaneously doesn't mean he has to =)
Summing should still be the easiest and most cheap solution to the problem.
Old 22nd June 2013, 11:35 PM   #6958
cheaper and easier than a switch to switch between them?
Old 22nd June 2013, 11:40 PM   #6959
Yup, a switch requires a person to move oneself to the switch and flip it, passive resistors just work =)
And if you have a switch then you must have the box that contains the switch accessible and can't hide the amp.
Old 22nd June 2013, 11:46 PM   #6960
Then I stand corrected!
Closed Thread
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
Copyright 1999-2017 diyAudio
