Hypex Ncore - Page 673 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Closed Thread
Old 25th April 2013, 08:37 PM   #6721
mangew is offline mangew  Sweden
Installed IEC inlet and Apem 641H on/off switch. Ok installation?:
Old 26th April 2013, 05:51 AM   #6722
Julf is offline Julf  Europe
Only minor thing I would change would be to try to route the power wires so that they don't run parallel to the signal wires.
Old 27th April 2013, 10:52 PM   #6723
Ok, finally after a long time i did finalize my ncore monoblock.
Was not sure how to connect earth to XLR contact. A picture:
I did connect shield from signalcable from ncore module to pin1 on XLR contact, this is not very visible on picture. Also did connect to same pin (1) an cable to chassi, And finally i did connect the black thin cable to the other fastening scew of XLR contact, not very visible on picture. I was not sure how this is done best and after looking at many pictures of others build i had no clear picture what was best since i did see a lot of different connections. Is my connection of XLR OK you think??
Also an picture of the whole amp:
[IMG]Click the image to open in full size.[/IMG]
I´m aware that some cables are unnecessary long, but did not want to cut them to short if i hade to make changes.
Have not tried them yet, any checklist beföre powering them up?
Old 28th April 2013, 06:18 AM   #6724
Only things I can think of is to make the shield from the signal cable go to the chassis screw instead of pin 1, and make the pin1-to-chassis cable even shorter, but those are really minor things - I think your system will be totally OK.
Do you have 2 wires per speaker outlet pin? I might have tried to keep the positive and negative twisted together slightly further along, and tried to avoid the loop in the speaker wires close to the amp circuits, but again, I don't think it will be an issue.
I tested the power supplies without amps (feeding a couple of power resistors) just to be sure - if you do that, make sure you allow lots of time for the caps to discharge before connecting the amps. I also tried with a cheap car loudspeaker first, before connecting an expensive speaker.
Old 28th April 2013, 07:21 AM   #6725
Thanks for advice, as you wrote belov i agree i shoud have done as you say. Mabye i correct to that wiring after i powered up and tested them which i haven´done yet. I thought that my wiring would be slighly the same since screen and pin1 cable would share contact anyway.
About the rest of the cables, speaker wire and also signalcable i will be shorten down when i tested and see if i have to do any changes.
Old 28th April 2013, 07:37 AM   #6726
It is the same - at low frequencies.
Old 28th April 2013, 03:13 PM   #6727
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Work in progress:
Old 28th April 2013, 03:34 PM   #6728
Does anyone know the typeface ncore logo has?
Old 28th April 2013, 03:43 PM   #6729
avr300 is offline avr300  Denmark
avr300's Avatar
Originally Posted by ds23man View Post
Work in progress:
Looking good.
Minor: Try to find some black screws for the connectors.
Old 28th April 2013, 03:49 PM   #6730
ds23man's Avatar
Originally Posted by avr300 View Post
Looking good.
In back order:
Thon Rack Screw M3x10 BK - Thomann Nederland
Closed Thread
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
Copyright ©1999-2017 diyAudio
