Hypex Ncore
Hypex Ncore
Closed Thread
Old 3rd April 2013, 08:49 AM   #6671
Julf is offline Julf  Europe
Originally Posted by Larsas View Post
Two good pages on grounding here, complete thread:
speaker terminals to chassis ground?
And perfectly summarized:
Originally Posted by AndrewT View Post
Safety ground must be attached to chassis.
Audio ground is usually separate from chassis.
They are two completely different animals.
However, to fully comply with the requirement that all exposed conductive parts must be connected to Safety Earth then many builders and some manufacturers adopt the debatable practice of directly connecting Audio Ground to Chassis.
Old 3rd April 2013, 02:07 PM   #6672
omainik is offline omainik  Austria
Default DC on input
Hello,
does the NCORE input circuit accept DC voltage on both inputs in relation to ground?
I am planning a new I/V stage for my dac, so it would be easier to accept a DC offset on both positive and negative output in relation to ground. in relation to each other it is easy to achieve zero volt dc offset.
thanks
Peter
Old 3rd April 2013, 02:11 PM   #6673
From the data sheet: Common mode rejection ratio: 55 dB, max input voltage +/- 15 V.
Old 3rd April 2013, 02:50 PM   #6674
troystg is offline troystg  United States
troystg's Avatar
Originally Posted by mangew View Post
Ok, a following up question.
Here are a picture as it seems to me a nice proper build, and here have the builder grounded the power supply with a wire directly to the ground on powersupply from the IEC inlet.
http://jamesromeyn.com/wp-content/up.../IMG_41171.jpg
I was thinkin to put a grounded wire from the IEC ground pin to one screw on the IEC and another wire from the powersupply (silver ground pin) to the other screw that fasten the IEC.
Is it better option to ground as shown in picture or the way i was thinking or it doesn´t matter?
Grounding 101.... The wheel has been invented long before us.
Grounding and Shielding Audio Devices
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 3rd April 2013, 04:07 PM   #6675
mike_mcf is offline mike_mcf  Canada
Well that sure covers the topic in detail.
Michael
Old 3rd April 2013, 06:02 PM   #6676
thank You Julf,
this helps me further with the design
Old 4th April 2013, 05:09 AM   #6677
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Before we write ten pages about grounding solutions, maybe it is wise to take a closer look at the NC400 and SMPS.
The baseplate of the NC400 is connected to the signal ground and 0v power connection. The metal stud of the smps is also connected to the 0v.
If you screw them in a metal case the signal ground is never floating!!!!!!!
And to prevent strange current flows the pin 1 of the XLR and the shielding of the input cable should be connected to the chassis.
Old 4th April 2013, 07:14 AM   #6678
Absolutely. But I think the issue and confusion is about the mains earth (the centre pin of a 3-pin IEC power connector). There is no need, from a signals point of view, to connect it to the chassis, but unless you know what you are doing, it is a good idea from a safety point of view.
The other issue is people who build their amps with acrylic or wooden enclosures without a metal chassis - they need to pay attention to their ground paths.
Old 9th April 2013, 04:07 PM   #6679
ufokillerz is offline ufokillerz  United States
looks like there's a new custom case maker making some monoblock cases for the ncore
The Emotiva Lounge - Kraemer Designs KD~D400 Hypex NC400 Mono Amp Build
Old 9th April 2013, 04:40 PM   #6680
ds23man's Avatar
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
