Hypex Ncore
Hypex Ncore
Closed Thread
Old 23rd March 2013, 07:14 PM   #6621
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
Originally Posted by Juhleren View Post
"plasitc-like"
you seem to have mind-reading abilities violins, cellos, double basses sounded just like that. and that is different from the ones I heard from the local philharmonic orchestra, which sounded like being made of wood.
sound that doesn't "breath" properly. It's like everything sort of sticks annoyingly together and produce a flat up front presentation with too little body in the bass
please, stop reading my mind, because I'm going to a concert and I'll likely be checking out the girls a bit.
though, I disagree with the glare, no glare with the UCDs.
An interesting experiment could be for you to deploy some small series resistors to the hot o/p terminals of your UCD amp. Try something like 0.22-0.1 R and "see" how that affects things.
did that in the past, not much change. in fact, I'd almost say I'd pe hard pressed to ABX that.
we all love a good ol' stereotype until it's against us
Old 23rd March 2013, 07:22 PM   #6622
Julf is offline Julf  Europe
Originally Posted by mr_push_pull View Post
euphonics? deliberately tuned?
no. that "no" is coming from my ears. because they tell me the AR amp fixed the anti-music the UCDs produced.
Unfortunately it does leave a possibility that the reason you don't like the UcD is that it is not like the AR - either because the UcD is bad, or because the AR is "good".
Old 23rd March 2013, 08:42 PM   #6623
EuroDriver is offline EuroDriver  Monaco
Default Did not like the steel top and bottom covers so
Originally Posted by mangew View Post
Damn, i did realise that the company i bought my chassis sent me the wrong type. I did order a Galaxy GX283 with 10mm aluminium front and it also should have alu top and bottom. The company sent me with 3mm front but that did i see directly and contacted them so a 10mm front is on the way. But now when i finally started to assemble the amps did i realise that they also sent me 2mm iron top and bottom not alu.
Is this ok with these nc400 and smps600 modules? Do the steel bottom/top make problem with any magnetic issues or? Normally most chassis for hifi is alu so i doesnt know if this will work fine and havenīt started to assemble them yet...
From my Galaxy chassis kit I ended up only using the side extrusions. I replaced the front, back, top and bottom with custom cut panels from Schaefer Home- Schaeffer AG - Frontplatten, Front Panels, Faces Avant
Thick aluminium panels have a lot less resonance than steel. I posted my build at audiocircle Show Us Your Core-NCore!
Old 23rd March 2013, 09:12 PM   #6624
mangew is offline mangew  Sweden
Should sound still fine. However alu is considered better in certain ways as you mention, and if you ordered and payed for something -that is what you should receive.
BTW, most hifi is stuffed in cheap magnetic steel place chassis. Its only the more expensive audiophile gear that typically (but not always) is built in alu boxes :-)
I have already sent some angry mails to the french company. Had to send some angry mails before they sent me 10mm alu front as i ordered and paid for. Let see if they send me the right top/bottom also since as you say i ordered and paid for that.
Ok, so i can assemble the amp then and see how it works and if/when i get the alu top/bottom i change. Been a long journey regaring my build of these NC400, still not at goal but now not to far away.
Old 24th March 2013, 12:24 AM   #6625
Esperado is offline Esperado  France
Banned
Is your amp microphonic ?
The only difference between alu and steel is a little less distortion due to electromagnetic induced fields: Just wire your amp for the cables stay > 2cm from the chassis walls.
Old 24th March 2013, 06:48 AM   #6626
Default No measurements but not taking any chances ;-)
I have a bugbear about micro phonics, and ringing , more relevant for analog amps, but when we are chasing the last remnants of noise and distortion . . .
I am a big user of Herbie's vibration control
Old 24th March 2013, 10:54 AM   #6627
Banned
There is hundreds of 'real' things you can improve before asking-you this kind of questions with solid state circuits...when it is impossible to measure any distortion changes produced by accelerations 1000 times higher than the ones produced by any acoustic level you can afford.
If you see something, hitting your boards with a tool, time to look for the poor weldings or defective components.
All those middle aged and blind audiophile black magic just bores-me.
Like Class D = digital = plastic.
It is boring, because it has no sense, is not correlated by any scientific evidence, by no measurement or *serious* listening experience, (on the contrary) and came back endless like the sea snake.
mr_push_pull, time for you to look at the defective part of your UCD system: enclosures (highlighted by high slew-rate ?) , HF parasitic components from your preamp, or any faillure in your UCD amps/PSU.
There is NO special sound signature to be identified from 'good' Class D amps. comparing to linear class A ones.
Old 24th March 2013, 12:45 PM   #6628
My Herbie's Tenderfoot foot story, is that I could hear a difference when my ZP-80 which was only feeding SPDIF to my DAC sounded better when sitting on Herbie's Tenderfeet ! I have no explanation whatever, but hey if I think it sounds better, what the heck
Old 24th March 2013, 03:05 PM   #6629
enclosure and slew rate? not sure what you mean. TBH I'd rather try a good NCORE implementation rather than trying to improve the UCD amp. I'm sure everyone agrees that the NCORE is indeed better. good enough for me? have no idea but I hope I'll get to hear it one day. I'd still take class D any day if it sounds good enough.
Old 24th March 2013, 03:44 PM   #6630
to robbby, I remember you having some noise issues, were they fixed? when switching to my new amp which has earthed ground I experienced ground loop issues (noise) because the DAC has earthed ground too. easily fixed with a cheater plug.
of course, the source of the noise itself can be either the DAC or the amp. one of them may act as a noise receiver.
in my case it was a cheap replacement SMPS for my laptop.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
