Hypex Ncore
Hypex Ncore
Closed Thread
Old 11th March 2013, 03:59 PM   #6531
Julf is offline Julf  Europe
Originally Posted by ua100k View Post
Can you tell us where you got that quote from
I guess from here.
Old 11th March 2013, 04:10 PM   #6532
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
you mean here: AudiogoN Forums: Merrill Audio VERITAS Amps: Any other experiances?
we all love a good ol' stereotype until it's against us
Old 11th March 2013, 09:39 PM   #6533
AP2 is offline AP2  Italy
Banned
Wow!....
DS450M Class D mono amp has a power reserve of 1368 joules of energy, way beyond the power reserve in the Merrill Veritas or the new upcoming M1 amps from Hypex coming out in June. The DS450M has over 176,000 microfards of capacitor storage. The large block transformer, choke regulator, and the Class D switching device in each DS450M amp are in house custom designs exclusive only to Audio Research.
why have used this big capacitors bank?
Mr.Push maybe know..
regards
Old 11th March 2013, 11:12 PM   #6534
DSP_Geek is offline DSP_Geek  Canada
Choke regulator? If that means a choke-input PSU, it's exactly the wrong thing for class-D -- at low output powers the supply voltage will rise to what a capacitor-input PSU would deliver, but at high currents the supply will drop to what a typical choke supply does, typically 0.7 the cap-input's rating.
And 175000 uF means lots of stray inductance before the switching transistors unless AR made sure they have scads of decoupling right at the devices. McCormack amplifiers didn't even have main filter caps -- they placed smaller caps at each output transistor, to apparently good effect.
Old 11th March 2013, 11:45 PM   #6535
klamia71 is offline klamia71
i experience a problme with my ncore
when i,m turning it on..the led are turning on nad then turned off and it doesn work at alla
has anyone experienc e something like that?
Old 11th March 2013, 11:56 PM   #6536
Juhleren is offline Juhleren  Denmark
Not necessarily -apparently Hypex SMPS600 deploys chokes on the HV rails too...
Old 12th March 2013, 01:21 AM   #6537
regards
yes, I do. but it's hard to explain.
Old 12th March 2013, 02:46 AM   #6538
robbbby is offline robbbby  Canada
Slightly off topic but what is this new hypex m1 amplifier? Google doesn't return much and I figured if some new amp is coming out in June from them there would be much more discussion about it.
Old 12th March 2013, 06:51 AM   #6539
Banned
If you really know (except that you have problems to explain), then you would not have said that the transient response audio does not have a relationship with the psu.
Unfortunately, the problem is that you do not know. Then stop attacking me.
Old 12th March 2013, 07:12 AM   #6540
The first thing to check for is a shorted output (maybe just a stray strand of your speaker wire?). If you are really sure there is no short on the output, I suggest contacting hypex, as there have been some nc400's with the overvoltage protection set to slightly too sensitive. It can be recalibrated, but it is a slightly complicated procedure requiring a stable and precise 3V source.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
