Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Class D Switching Power Amplifiers and Power D/A conversion |
#6301 |
Thanks again
. R141=Rg=1.2k Rf=2.2k for the NC-400 model that is what I found in one of the Brunos post Yes There is no need to change the Rf i was just curious Thanks now it is clear I just need +3db additional gain...
#6302 |
Just be aware that increasing gain lowers the feedback. While Bruno has commented that increasing feedback is OK, I think you might be in somewhat uncharted waters if you actually lower the feedback from the nominal.
Very interested in hearing your experiences if you try it. |
#6303 |
According to the present datas should be something like this
(for the 680 ohm Rg, +4db input stage gain)
#6304 |
Quick question. Can someone point me toward the connector for J1 on the SMPS? I have looked for item # JST-B7B-EHA on Digikey, with no luck. This looks like it, but not the correct item #. I seem to have thrown out the ones that came with my units and need them now. Thank you |
#6305 |
Ask Hypex?
#6306 | |
455-1005-ND - Housing. 455-1042-1-ND Crimp
Audio Purity |
#6307 |
While we are at it, would someone know the exact reference of the female crimp terminal to use with the microfit molex connector 43025-1200 ?
I think it is the 43030, but several version exists: View List What is the AWG of the wire? I would like to fit 2 (or myabe even 3) wires per connector, so if the original AWG is 24, 2 of them should fit no problem in the 20-24 AWG model... Also, do you know if special tools are required to assembled those crimps, or will a simple crimp tool be sufficient? |
#6308 |
My 3 monoblocks with bridged nc400 and SMPS1200A400, built by my friend Georg.
We have compared them against the standard nc400+SMPS600 in a dual-mono config today. The bridged ones sounds much more "alive", and they are not even broken in. The standard ones sounds flatter. Less dynamics. The monoblocks has version 4 of nc400. The dual-mono has version 3. What was the changes made in version 4? |
#6309 |
Did you do the comparison as a double-blind ABX, or as a sighted subjective evaluation?
#6310 | |
Thread | Thread Starter | Forum | Replies | Last Post |
Hypex Ncore vs. NAKSA | AlliumPorrum | Class D | 1 | 26th May 2015 06:36 PM |
Problem with Hypex Ncore | Koifarm | Class D | 29 | 13th October 2014 06:32 AM |
Any news on hypex ncore 2.0? | JZatopa | Class D | 1 | 13th August 2013 10:30 AM |
Hypex UcD700 vs NCore | Earbound | Class D | 25 | 15th March 2013 04:10 PM |
Building a Hypex Ncore... | Jabbejokker | Class D | 0 | 7th March 2013 09:08 PM |
New To Site? | Need Help? |
