Hypex Ncore
Hypex Ncore
Closed Thread
Old 24th January 2013, 09:14 PM   #6191
sonnenwender is offline sonnenwender
Default Symmetrical cables for Ncores
Thanks for the many hints. Did anyone try Mogami cables? Given that Bruno uses them for the signal cabling inside the Ncore that might not be a bad idea. I wouldn't know in what form Belden cables come when ready made (probably they are used by some brands available in Germany)...
Old 24th January 2013, 09:47 PM   #6192
Steidl Guitars is offline Steidl Guitars  United States
I did and found them to be quite neutral (and cheap). In the end, I stayed with my "standard" cable, Acoustic Zen Wows, which tend to be a bit more forgiving. I liked the Mogami just fine though, and might even prefer them in a different system.
Old 25th January 2013, 03:31 AM   #6193
HFGuy is offline HFGuy  Canada
mfb nice chassis, where did you get them ?
Old 25th January 2013, 03:54 AM   #6194
DSP_Geek is offline DSP_Geek  Canada
Originally Posted by Esperado View Post
We have enough, oh my God, enough, yes, of real problems to solve in audio electronic in order to reproduce sounds in a credible way.
Bruno, a very good engineer, has demonstrated how, with a real scientific approach you can solve most of those problems. and offer for a reasonable price, a near ready to use amplifier witch is, no contest, one of the best in the world. Despite it is an evil Class D.
Bruno also indicates his feedback loop topology is firmly grounded in control theory -- and that it can be extrapolated to other Classes of amplifiers. One does want to keep load impedance issues from changing the response at unity gain, so a Zobel-type network on the output is probably useful.
Most likely Class-D makes it simpler because the poles and zeros are determined in the front end, whereas I suspect (haven't designed one myself) some zeroes are found in driver and output stages of linear amplifiers. Those poles & zeros may vary because of transistor process spread, making a consistent solution an exercise in optimism.
Old 25th January 2013, 04:16 AM   #6195
Originally Posted by ds23man View Post
Or put a 16R resistor in series with your 16R driver, the ncore will be limited to 50 watt and the resistor will soak half of it so you will have a nice an healthy 25 watt at the driver.... Should be sufficient for home applications.
The impedance curve for horn drivers is anything but flat, so the voltage division will be non-flat also.
Old 25th January 2013, 04:48 AM   #6196
Originally Posted by barrows View Post
That some folks think Mr Putzeys would not be in favor of relatively expensive cabling, considering his company Grimm Audio actually makes and sells some fairly expensive high end cabling.
It's low-triboelectric, also with more RFI shielding than most other cables, so his stuff does make sense.
Old 25th January 2013, 08:00 AM   #6197
rilke1999 is offline rilke1999  Germany
I use mogami broadcast cable with neutrik or card as xlr connectors. It's a no nonsense combination connecting my bridges ncore monos to a ml380s. A pair (incl some nice "Gewebeschlauch" haven't found this word) of 4 m is less than 100€.
This cable does not add anything and is very tolerant for longer length.
Drop me a pm for the source.
Br
Mka
Old 25th January 2013, 10:07 AM   #6198
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
search for "low noise cables", there are a lot of companies making low triboelectric effect cables for industrial uses. shielded too, all sorts.
we all love a good ol' stereotype until it's against us
Old 25th January 2013, 12:01 PM   #6199
Juhleren is offline Juhleren  Denmark
Originally Posted by rilke1999 View Post
I use mogami broadcast cable with neutrik or card as xlr connectors. It's a no nonsense combination connecting my bridges ncore monos to a ml380s. A pair (incl some nice "Gewebeschlauch" haven't found this word) of 4 m is less than 100.
Br
Mka
Is correctly understood that you run bridged ncores?
If so, have you tested the bridged config against the standard config and found any audible differences besides the ability to swing more voltage?
Old 25th January 2013, 02:17 PM   #6200
Actually I decided to go back to my previous configuration biamping my BW 803di. The bridges configuration only a minimal audible effect, while with the biamped configuration added transparency in the mid range and resulted in a better placement of instruments especially in complex orchestral word.
I will sell my ml 332 now, I am convinced.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
