Hypex Ncore - Page 62 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Closed Thread
Old 18th October 2011, 02:41 PM   #611
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
Originally Posted by phase_accurate View Post
I think the last answer was uncalled-for.
The poster asking the question about crossover distortion didn't make any posts in this thread before (so neither ranting ones). As far as I could see he was not even posting in class-d at all so one can assume that it was 1.) a honest question and 2.) he isn't aware of the special crossover distortion mechanisms that come into play with class-d amplifiers.
Agreed
Class-d in general do have a very different crossover behaviour than linear amps. There is always an alternating idling current flowing through the output inductor at no or low output power. This current is greatly supporting the switching process. At the very point when the output current in the load approaches the value of the idling current a class-d amp's crossover takes place. This is usually at a few watts. There are amps where this is intentionally pushed to higher output power levels by the use of smaller inductors (and therefore increased idling current). IIRC it was mentioned within the thread where this takes place for the ncore and if my memory serves me right it is between 20 and 30 Watts. Or in other words: At quite high output levels from a domestic point-of-view.
Charles
Which possibly/probably explains the 'bump' in the THD plots for the ncore at about 30W into 4ohms
http://www.hypex.nl/docs/nc1200%20folder%20web.pdf
Old 18th October 2011, 03:51 PM   #612
Originally Posted by ChrisPa View Post
Agreed
And if so probably also the bump at 60-70W on the 8R plot.
(same current flow but double the voltage...)
The nice thing is the very low distortion plateau beneath these bumps which are very useful for most domestic listening
- on the assumption that low distortion relates to good sound of course
cheers,
Old 18th October 2011, 04:43 PM   #613
Default I will
probably build up a nCore amp with the hopes that it will sound good enough for me to make the switch from A and A/B amps to class D for good. I sure would like to save the energy.
I have heard the uCD 400s here (with the Hypex deluxe linear supplies and HrX regs) and have a pir of ICE ASP 500 based monoblocks around as well. The uCD 400 was the best sounding class D amp I have heard, but still lost out to a traditional class A/B amp (Pass Labs X 150.5) for listening.
I look forward to the nCore DIY modules availability with high hopes.
Old 22nd October 2011, 10:53 PM   #614
Will the nCore modules be available as a plate amplifier? I would really like to simplify my components and make my speakers active. A plate amp would certainly make the conversion easier.
Old 26th October 2011, 09:06 PM   #615
when, when, when ?
Old 30th October 2011, 09:53 PM   #616
Charles,
Very interesting; I had thought that crossover distortion wasn't an issue for class D because they don't construct the output waveform from two halves like AB design.
I guess this would be true for the IRS2092-based modules?
The only evidence I see in the curves starting on p.8 here
http://www.inductor.com/irf/iraudamp7s.pdf
is a small bump at 20W in some of the THD+N vs. power graphs, though curiously only in one channel.
What is the freq of this alternating idling current?
If the same as the PWM freq wouldn't it be inaudible?
Noah
Old 4th November 2011, 12:22 PM   #617
Default Ncore demo
Yesterday the Ncore amplifier demo was very convincing, both in theory and in an amazing experience in listening to music, not hearing any additions!
I hope to get 8 of these baby's for my new to build dig. controlled active system. Bruno, good luck!
Old 4th November 2011, 01:25 PM   #618
jmbulg is offline jmbulg  Belgium
What kind of installation did you use for the listening test? Any infos on the release date ?
Old 4th November 2011, 02:30 PM   #619
cOz is offline cOz  United States
Seems like these should be getting close to being released. I'm excited to see the release details like date and price!
Old 4th November 2011, 04:32 PM   #620
Ask Bruno for specific details, for it was organized by Hypex together with AES section NL.
Active loudspeakers: SEAS tweeter and mid; bass: Peerless
(think it was...)
Closed Thread
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 07:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 07:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 11:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 05:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 10:08 PM
Copyright 1999-2017 diyAudio
