Hypex Ncore
Hypex Ncore
Closed Thread
Old 17th October 2011, 10:02 PM   #601
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
There must be some form of correlation between measured and audible performance, but much of our more traditional (simplistic) published measurements haven't provided an especially useful correlation.
My interpretation of what Bruno has written (I can't speak for him) is that he believes he can demonstrate an improved correlation between measured and perceived performance than has existed previously. What I find interesting about his approach and developments is that they they appear to be driven from the basis of hearing things first then trying to determine what to measure and how to design to achieve those audible results.
From a philosophical point of view I've come to the opinion that the role of a power amplifier should probably be the distortionless, frequency-independent control of any load it's connected to. if there are euphonic distortions that can increase our listening pleasure (though I'm not convinced there are) then these should be generated before the power amp. That is the roll of eq and effects within the recording chain.
Different amps do sound different and do affect my (our) pleasure with this illusion engine. But it always strikes me as strange that the recording chain uses so many devices and processes that we believe we shouldn't dare use in the replay chain
Old 17th October 2011, 10:22 PM   #602
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
there is a lot of subtext in your messages, but you pretend otherwise. one can clearly read "I think UCD is crap and most likely nCore will be too". what I do not like is that you are trying to present things like you didn't think that.
phrases that slip "by accident", like that one "let's look at the past performance of class D amps" have an obvious purpose and that is to instill the idea that UCD or nCore are nothing but successors in a line of known poor performing products.
for one, I'm sure you are incapable to prove or explain the supersonic performance degradation.
for me it's ok that you like AP2's products, although I would think that you've listened to his products before holding on to an opinion, based on the fact that I haven't and never saw any measurements, relevant or not. repeating statements like "I like his approach more" adds no information. his products may indeed be better but at this point I have no basis whatsoever to believe that. OTOH I have more reasons not to take the guy seriously and believe Bruno.
I would not be surprised if you'll think that nCore sucks while I will disagree. just to emphasize the futility of this discussion.
Old 17th October 2011, 10:23 PM   #603
pieter t is offline pieter t  Netherlands
I am curious to learn more about that.
What I have missed until now is a FFT distortion plot (Bruno was asked for a distortion spectrum back in June) because this tells us at least something about the distortion spectrum (2nd, 3rd a.s.o. harmonics). These spectra can provide useful information; FFT plots are pretty common nowadays, and seem to have more correlation with sound quality.
The THD curves which Bruno provides in his white paper look very good, but it is also known that low measured THD and perceived sound quality not seldom don't correlate at all.
Old 17th October 2011, 10:49 PM   #604
Yes completely agree.
Look at sound reproduction as having microphone(s) at the beginning, and loudspeakers at the end.
These are generally the weakest elements in the chain (being converters from acoustic to electric and v.v.), so their quality matters most IMO.
Everything in between is for processing, amplifying a.s.o. and this is in the electrical domain where distortions are a magnitude lower.
So also the power amplifier should merely do his (electrical) job by amplifying the signal and feed it to the loudspeaker with minimal loss of quality.
I have been lucky a couple of times to have been present at recording sessions of the Dutch Radio Philharmonic Orchestra, where the "minimal" microphone technique approach was used (two microphones in stead of a large number for each group of the orchestra, so very much depends on microphone placement and communication between recording engineer and conductor). I can tell you this is art, and very much of the quality we hear at home depends on the quality of the recording.
Maybe good to realize when arguing about amplifiers....
Old 17th October 2011, 11:10 PM   #605
Pano is offline Pano  United States
Pano's Avatar
Hypex Ncore
Have we lost the topic of this thread? Gentlemen, please.
Old 17th October 2011, 11:12 PM   #606
No just some relaxation which this thread could use.
Old 18th October 2011, 06:39 AM   #607
StigErik is offline StigErik  Norway
StigErik's Avatar
Yeah guys, just sit back and chill while we wait for Ncore .....
Ncore - this year's x-mas present from me to me!
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 18th October 2011, 06:56 AM   #608
Omholt is offline Omholt  Norway
Omholt's Avatar
Hypex Ncore
Question:
Does the Ncore amp have any crossover distortion? If it does, has it been measured?
Old 18th October 2011, 08:32 AM   #609
Originally Posted by Omholt View Post
Question:
of course it has crossover distortion, like any class D amp in existence. it's only that measurements have been faked. didn't you know?
guys, I'm unsubscribing from the thread too. I used to think of DIY audio as the only forum I know where even a heated discussion can be pleasant. I've come to change my mind. I'm absolutely convinced that this topic is poisoned with people that have other intentions than to reveal truth.
Old 18th October 2011, 09:11 AM   #610
phase_accurate is offline phase_accurate
I think the last answer was uncalled-for.
The poster asking the question about crossover distortion didn't make any posts in this thread before (so neither ranting ones). As far as I could see he was not even posting in class-d at all so one can assume that it was 1.) a honest question and 2.) he isn't aware of the special crossover distortion mechanisms that come into play with class-d amplifiers.
Class-d in general do have a very different crossover behaviour than linear amps. There is always an alternating idling current flowing through the output inductor at no or low output power. This current is greatly supporting the switching process. At the very point when the output current in the load approaches the value of the idling current a class-d amp's crossover takes place. This is usually at a few watts. There are amps where this is intentionally pushed to higher output power levels by the use of smaller inductors (and therefore increased idling current). IIRC it was mentioned within the thread where this takes place for the ncore and if my memory serves me right it is between 20 and 30 Watts. Or in other words: At quite high output levels from a domestic point-of-view.
Charles
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
