Hypex Ncore
Hypex Ncore
Closed Thread
Old 18th January 2013, 03:02 PM   #6081
ds23man is offline ds23man  Netherlands
ds23man's Avatar
To put things in perspective:
You can lower the gain of the ncore with 13db and in combination with a 113db compression driver you still have a 100db sensitivity. Combined with direct radiating drivers there is still a big mismatch......
Old 18th January 2013, 03:20 PM   #6082
akasha is offline akasha  Denmark
you take parts out of the whole equation
lower the gain of the ncore will not change the sensitivity of the compression driver
Old 18th January 2013, 03:43 PM   #6083
ds23man's Avatar
Depends from which side you are looking. From the active crossover side you still need to att. the compression driver.
Old 18th January 2013, 03:59 PM   #6084
true, but in case with too much gain as well as noise, is better to attenuate noise as well as signal before the ncore instead of reducing gain of the ncore, whatever comes from ncore will still be used with 113db sensitivity
Old 18th January 2013, 04:28 PM   #6085
ds23man's Avatar
Or put a 16R resistor in series with your 16R driver, the ncore will be limited to 50 watt and the resistor will soak half of it so you will have a nice an healthy 25 watt at the driver.... Should be sufficient for home applications.
Old 18th January 2013, 04:35 PM   #6086
and some might not even notice before a proper ABX test
Old 18th January 2013, 05:01 PM   #6087
ds23man's Avatar
And it is wise to put a capacitor in series with the driver as a safety device, remember the ncore is dc coupled! It would be very if a high DC voltage is applied to a nice TAD 4001 750 dollar diaphragm......
I am building a system with B&G RD-50's and I will put in a series C, if something goes wrong it would be a nice 50" Led Line for a short period......
Old 18th January 2013, 05:07 PM   #6088
ds23man's Avatar
And they will not hear anything again after an ABX test with 25 watts on a 113db driver......
Old 18th January 2013, 05:19 PM   #6089
may I reccomend:
Duelund Chorent audio have some nice ones called "Cast" series silver: only 1200-EUR for 10uF (1 pc.) you can barely hear them
Old 18th January 2013, 05:52 PM   #6090
Julf is offline Julf  Europe
Especially on cold nights like this...
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
