Hypex Ncore
Hypex Ncore
Closed Thread
Old 13th January 2013, 03:33 PM   #5931
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Originally Posted by Julf View Post
Maybe you want to be able to play really loud?
Independent of your speaker sensitivity or amp power, you might have a situation where the last 10 dB of input amplitude make the amp clip. Lowering the amp gain 10 dB still allows you to play at full volume, but gives you 10 dB extra signal-to-noise ratio.
Yes, and lowering the gain in the preampstage will give you also 10db extra signal to noise ratio. The noise is comming from the preamp stage, not the Ncore! Btw, how many 100db+ speakersystems can cope with 200watt+ input levels???
Old 13th January 2013, 03:36 PM   #5932
Julf is offline Julf  Europe
I guess that depends on your peamp - and some of the noise might come from your attenuator.
No idea - but I also don't see what it has to do with the discussion about amp gain. Why would you want to use a 200W+ amp for a speaker system that can't handle the power?
Old 13th January 2013, 03:45 PM   #5933
ds23man's Avatar
Well the guy who ****** up his ncore does
Old 13th January 2013, 03:57 PM   #5934
Well, yes, he did state that he need to lower the gain with his 100dB speakers, but it is still possible that that was to avoid clipping rather than for avoiding blowing up his speakers or ears.
Old 13th January 2013, 04:38 PM   #5935
ds23man's Avatar
Old 13th January 2013, 06:08 PM   #5936
Paulkouhan is offline Paulkouhan
I use a passive preamp (TVC) after a 5V output balanced DAC.
The very fist step of the TVC is a bit loud for "night" listenings.
I also plan to use a DSP with digital volume control so I definitely need to lower the gain. It is as simple as that.
Before my message there was no serious warnings about removing the resistor, everybody said it was easy ...
After my message, we find 2 other people that had some problems !
Old 13th January 2013, 06:42 PM   #5937
BertDB is offline BertDB  Belgium
BertDB's Avatar
that all depends on your skills and experience in SMD (de)soldering, and is in fact not related to the nCore itself.
Some will find it easy, others will find it difficult..
It proves that a lot on the internet is subjective and should be red with care
Nevertheless, it's a pity that your amp died
Old 13th January 2013, 07:12 PM   #5938
I definitely reported, in this thread, killing one of my nc400īs when desoldering R141 at the time it happened.
Old 13th January 2013, 11:10 PM   #5939
Regnad is offline Regnad  United States
Originally Posted by dan92075 View Post
Hi Regnad - now I am confused
Do you mean to say that the NC400 with 6" speaker wire outperforms the NC1200 with the longer speaker wire?
I thought you were indicating in an earlier post that the NC1200 sounded better even when using longer speaker wire?
Appreciate if you could clarify - thanks!
Sorry, I meant that the NC400 amps with short speaker cables were better than the NC400 with longer ones. I think that the NC1200 is better still but so much of this is synergy and many other things. One thing is for sure, with the NC400 I considered unhooking the subs and with the NC1200 it was certain. I have not tried short speaker cables with the NC1200 amps.
Old 14th January 2013, 05:26 AM   #5940
dan92075 is offline dan92075  United States
ok - thanks - that makes sense now!
also, out of curiosity how long and what size is the cable with the NC1200?
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
