Hypex Ncore
Hypex Ncore
Closed Thread
Old 13th January 2013, 11:36 AM   #5921
Julf is offline Julf  Europe
Originally Posted by ds23man View Post
Why do people always want to change the gain? If you have high sensitive speakers, put a attenuater between your ncore and preamp!
What Is Gain Structure
Old 13th January 2013, 11:41 AM   #5922
StigErik is offline StigErik  Norway
StigErik's Avatar
It makes a lot of sense for us that run the DAC output straight into the Ncore.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 13th January 2013, 12:16 PM   #5923
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Yes, and a nice big wirewound potentiometer between the amp and speaker
Old 13th January 2013, 12:24 PM   #5924
ds23man's Avatar
I know what gainstructure is, been in pro audio for many years.
What I mean is the ncore has an output noise of 25uV and a signal to noise ratio of 125 db. Gain is only 26 db ( most pro audio amps are 36db). So if you get a hiss out of your speakers, the gainstructure before the ncore is wrong.
You have to solve the problem at the source!
Old 13th January 2013, 12:32 PM   #5925
I know you would know, that is why I was surprised you would ask.
There doesn't necessarily have to be a problem - but why would you on purpose give away some SNR? And Bruno has commented that the performance of the nc400 does improve a tiny bit with increased feedback (which is what you get if you lower the gain instead of attenuating the signal).
Any attenuating network will always compromise the impedance matching between source and amp to some degree. Whether it makes any audible difference is another matter, but why eschew an ideal solution in favour of an inferior one at the same cost and effort?
Old 13th January 2013, 12:50 PM   #5926
TheShaman is offline TheShaman  Europe
Originally Posted by Julf View Post
...but why eschew an ideal solution in favour of an inferior one at the same cost and effort?
Well, it seems that the relatively simple task of desoldering an SMD resistor can turn into a disaster for quite a few people.
Considering NC400s are not exactly affordable modules, if one is not confident with his soldering skills, he'd be better off using attenuators.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 13th January 2013, 12:56 PM   #5927
ds23man's Avatar
Or reduce the gain of the preceding stage, the noise floor will get lower if you do that. Soldering on these modules is like Russian roulette for most of us.
Old 13th January 2013, 01:29 PM   #5928
Definitely the easiest solution if there is provision for it. Many of us have sources with limited gain range.
Right - but this is DIYaudio after all
I agree that people should be aware that the removal of R141 requires precision soldering and can go wrong.
I was simply responding to the question posted by ds23man, "Why do people always want to change the gain?", by pointing out there are good reasons to do it. Is it worth the risk? That's a different question.
Old 13th January 2013, 03:11 PM   #5929
ds23man's Avatar
We can put this in another way: If I have high sensitivity speakers ( 100db+), why I want to use a high power amp?
Old 13th January 2013, 03:26 PM   #5930
Maybe you want to be able to play really loud?
Independent of your speaker sensitivity or amp power, you might have a situation where the last 10 dB of input amplitude make the amp clip. Lowering the amp gain 10 dB still allows you to play at full volume, but gives you 10 dB extra signal-to-noise ratio.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
