Hypex Ncore
Hypex Ncore
Closed Thread
Old 31st December 2012, 09:35 PM   #5811
cjf is offline cjf  United States
Hello, thanks for your response but I don't think I understand what this means. Is "UcDxxxHg + HxR" different or the same technology as what is found in the NC400 everyone is building?
Has anyone attempted to team one of these NC400 amps with a traditional Class A/AB amp in a Bi-Amp configuration? If someone were to do this and taking into consideration the NC400's electrical behavior while attached to a speaker load which half of the speaker would be best suited for this type of Amp (ie..Mid/Tweet or Bass Drivers section)?
For the sake of example, lets say the speaker in question is a B&W 803 Diamond and the Class A/AB amp is a Pass Labs X250.
Old 31st December 2012, 11:09 PM   #5812
kuribo is offline kuribo
go to Hypex's web site and read their product info.
Old 1st January 2013, 11:53 AM   #5813
Julf is offline Julf  Europe
Originally Posted by Paulkouhan View Post
Do I need to add a soft start ?
No, the SMPS600 has a built-in softstart.
Can I use a wood enclosure ?
Sure, as long as you ensure sufficient cooling, and pay attention to ground/earth issues.
Old 1st January 2013, 02:18 PM   #5814
OllBoll is offline OllBoll  Sweden
The designer Bruno has described that the superiority of the NCore is in the midrange and upwards, especially in the high frequencies. In the bass he recommended the UCDs since he didn't seem to believe there would be any improvement here by using the more expensive NCore as long as it was a proper active setup.
Old 1st January 2013, 04:19 PM   #5815
StigErik is offline StigErik  Norway
StigErik's Avatar
That is not true. If you look at the distortion graphs for both UcD and Ncore, you clearly see that the Ncore is superior in the bass range as well, and those superior specs are indeed audible.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 1st January 2013, 04:32 PM   #5816
Sure, but the drivers themselves distort much more more in that region. I'm more inclined to believe Bruno
Old 1st January 2013, 04:33 PM   #5817
Is that a purely subjective opinion, or have you done some proper double-blind ABX listening?
Old 1st January 2013, 04:35 PM   #5818
StigErik's Avatar
They distort a lot more than the Ncore in the midrange the treble as well. In general, no speakers have less than 0,3% harmonic distortion, and usually the IMD figures are very bad.
Old 1st January 2013, 04:35 PM   #5819
StigErik's Avatar
Yes and yes.
Old 1st January 2013, 04:38 PM   #5820
Yes and yes.
Good answer!
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
