Hypex Ncore
Hypex Ncore
Closed Thread
Old 21st November 2012, 02:33 PM   #5531
Julf is offline Julf  Europe
Originally Posted by bavmike View Post
My current DAC only puts out 3v and it's not enough. That's one of the reasons I'm looking for a new DAC.
The voltage gain of the nCore is 26 dB, or 20 as a gain ratio. 3 V x 20 is 60 V. 60 V into 4 ohms is 900 W. That is not enough?
Old 21st November 2012, 02:42 PM   #5532
bavmike is offline bavmike  Canada
Banned
I haven't done any calculations, just personal experience. The manufactures rated output of my DAC is 3v rms. With my speakers which are 89db efficiency and some other towers I've tried which are 92, I'm not getting enough output. Now when I replaced my DAC with the PS audio perfectwave MkII, (which I think outputs 4.5v) it was a perfect match. Turned up to 60% on the perfectwave's volume control, it matched the output of my dac which doesn't have a volume control. Now if you have really efficient speakers or don't listen at loud levels this might not be a problem for you.
Old 21st November 2012, 02:56 PM   #5533
OK, but do you disagree with the numbers I presented above? The implication is that if you go above 2 V on the input, you will cause the nCore to clip (or at least exceed the 1% THD Hypex specifies at max rated power).
Whatever the efficiency of your loudspeakers, you don't want to drive your amps to clipping.
Old 21st November 2012, 03:03 PM   #5534
Banned
No I don't disagree with your calculations. But I definitely haven't driven my ncores to clipping. They sounded clear as a bell with zero strain at every level I've listened at. But I am listening to music not sine waves.
Old 21st November 2012, 03:10 PM   #5535
Right - that makes me think something in your source might be attenuating the signal to the DAC. What are you using as your source?
Old 21st November 2012, 03:18 PM   #5536
Just to be sure, I went back to check. In this posting, Bruno states "Since gain is (very nearly) 20x, you need 2Vrms for full power. "
Old 21st November 2012, 03:25 PM   #5537
Banned
I use my macbook pro with either Pure music, or Audirvana on OSX, or Jriver on my Windows 7 side. The DAC is a Eastern Audio Minimax plus. It has both tube and SS output stages. The stock tube output stage with stock tube is rated @ 3v RMS. I've upgraded the opamps on the SS side which further increased the output on the SS. So I'm not sure what the SS is putting out but it's more then the tube and is still not enough for me. The PS Audio connected to the same computer and software puts out more then enough.
Old 21st November 2012, 03:27 PM   #5538
Banned
Yes with some louder recordings on my SS output it is enough. But I like to have the extra gain on tap for when I'm listening to quieter recordings. He's probably talking about full power playing back white noise or something
Old 21st November 2012, 03:45 PM   #5539
Would be interesting to measure how much it actually puts out. Do you have a 'scope?
Old 21st November 2012, 03:47 PM   #5540
The content of the signal doesn't matter. A voltage is a voltage. But in any case, the way most modern popular music is compressed to death, it is close to playing full-level white noise anyway
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
