Hypex Ncore
Hypex Ncore
Closed Thread
Old 15th November 2012, 11:10 PM   #5441
barrows is offline barrows
Default Not sure...
Originally Posted by toufu View Post
Thanks for answering the question regarding linear PSU.
Is there a reason to use the switching PSU instead of linear? As the linear would probably be cheaper, would it be better?
How you think you could make a quality linear supply with the necessary voltages and current for less than what the SMPS 600 costs?
Old 15th November 2012, 11:12 PM   #5442
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
A regulated linear supply would be expensive and difficult to do. It would have to support 800W.
Old 15th November 2012, 11:18 PM   #5443
toufu is offline toufu  United States
You don't need the regulated high voltage, just the low voltage (18V), right?
Old 15th November 2012, 11:25 PM   #5444
That's more of a compromise typically used for Class AB amps which draw current all the time. Class D will have more voltage sag as it is more efficient. A well-designed SMPS is fully regulated and can deliver clean power.
Old 15th November 2012, 11:32 PM   #5445
Default yeah...
But to deliver enough current with a linear supply, you are going to need some decent iron as well, quality diodes, quality capacitors. This stuff adds up pretty quick, especially if you are going to do dual mono supplies. A SMPS does not need the big iron, so saves parts costs in big ways...
Old 16th November 2012, 02:46 AM   #5446
yetis is offline yetis  United States
So I have finally received my custom case and it is a beauty! I will show when its all done. Its a three channel case that is 2U and custom made to support three amps and power supplies, along with xlr only connections and bi amping for all three channels! And this time, it actually provides ventilation, unlike some other cases... My question is about the power application. I have purchased, in the past, molex connections for my custom connections, but now I am feeling a little bold and want to try direct soldering of the power supplies. Is it possible, there is any benefit, or is such an endeavor just all potential downside? Has anyone ever done this? If I did it, whats the best way to insulate the soldered connection?
Thank you
Old 16th November 2012, 05:22 AM   #5447
Julf is offline Julf  Europe
In addition to the factors others have mentioned, I have to add the obvious ones:
- size
- weight
- heat
- power consumption
Old 16th November 2012, 07:47 AM   #5448
StigErik is offline StigErik  Norway
StigErik's Avatar
Originally Posted by fas42 View Post
People frequently talk of the bass improving, but it has absolutely nothing to do with the actual bass frequencies; it's actually the transients and higher harmonics being reproduced properly that creates the subjective impression of better bass.
I have an active system crossed over at 200 Hz. Even so, I experienced improvement in bass quality when I changed the woofer amps only. Transients and harmonics were not affected by this amp change.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 16th November 2012, 08:56 AM   #5449
fas42 is offline fas42  Australia
Banned
Fair enough, it's just that I've seen comments so many times implying that the deep bass frequencies are somehow "better", when it's clear that that it's frequencies higher in the spectrum that are better behaved. Experiments have shown that people are enormously insensitive to distortion in the deep bass area, eg. 100% additional distortion is not detected. But if the woofer driver is producing less harmonic distortion above, say, 200Hz because the amp change is controlling it better then it would make sense ...
An interesting experiment would be to disconnect all but the bass amps, and then compare the sound of the two amps when only that part of the spectrum is being reproduced.
Frank
Old 16th November 2012, 09:05 AM   #5450
StigErik's Avatar
I have done that test in my system, and I could hear a difference. Listening to music that way is really strange... I XO at 200 Hz with fairly steep crossover slope. The bass sounds anything but "fast" and precise.... is all very muddy.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
