Hypex Ncore
Hypex Ncore
Closed Thread
Old 24th October 2012, 10:02 AM   #5261
Mark Verhoeven is offline Mark Verhoeven  Netherlands
Originally Posted by Julf View Post
Disconnected - but observe electrical safety rules inside your box...
So, it's better to have no "ground" connection to the IEC connector?
Old 24th October 2012, 11:30 AM   #5262
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
nc400 datasheet
section 12.3
specifically section 12.3.1
and figure 2
Old 24th October 2012, 11:33 AM   #5263
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
Originally Posted by Johanson View Post
Can't find it on the Hypex website, could someone point me to it, and what program I would need to open the file on my computer. Do you save it as a PDF, or in pictures. I did try the file posted by mr_push_pull and downloaded WinRAR but I couldn't open the file unless I was doing something wrong. Thanks.
I guess there are tons of apps that can read the .dxf format but I use DraftSight (AutoCAD clone).
http://dl-ak.solidworks.com/nonsecur...aftSight32.exe
we all love a good ol' stereotype until it's against us
Old 24th October 2012, 11:52 AM   #5264
Originally Posted by ChrisPa View Post
nc400 datasheet
section 12.3
and figure 2
I did use the balanced connection like in figure 2 except for the ground connection, I did actually connect the IEC ground to the chassis.
I don't have ANY hum at all (perhaps due to my source having balanced output transformers), can there be any other sonic improvement if I remove the ground connection to the IEC connector?
Old 24th October 2012, 12:06 PM   #5265
ChrisPa's Avatar
from section 12.3.1
"No safety earth connection was depicted. This is entirely acceptable if class II construction is used
throughout. Otherwise, connect the safety earth."
Connecting the mains earth gives an additional noise path - which doesn't mean that there will inherently be noise waiting to go down that path
Noise isn't just mains hum. It's any signal of any form or frequency composition that is not part of the original signal or a distortion within the original signal.
Whether that noise has an audible effect or not on the original signal is another matter. The recommend configuration in the data sheet gives you the best option for overall noise rejection. If you kept with class 2 construction you don't need the mains earth. Removing the earth may have no audible effect in your system.
Old 24th October 2012, 12:38 PM   #5266
O.K. thanks, I'd better open the casings soon. I also can fit the new input cable at the same time.
Old 24th October 2012, 08:39 PM   #5267
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Originally Posted by Bultrug View Post
...... going from the amplifier modules to the speaker binding posts. I understand these wires will be unshielded and are to be twisted, but what type/size (alloy/awg) would be best to use?
I chose some silver wire that I had laying around for the simple reason that they are NOT flexible and thus would stay put after twisting them. AWG is not that important for the ~10cm length of the wires from the amp to the rear of the cab
Old 25th October 2012, 09:26 AM   #5268
klamia71 is offline klamia71
my boxes..
Old 25th October 2012, 06:26 PM   #5269
Turbonsx is offline Turbonsx
Default Confirmation on input to output gain math
Just wanted to see if some could confirm that if I wanted to increase the gain ratio from input to output, that I should choose a value for RG of under 1.2k.
For instance: a resistor value .800 mf would increase the gain multiplier to 6.5 as opposed to the factory 1.2k mf giving a gain multiplier of 4.67.
I'm basing the total gain off of: 4.17(1+2*RF/RG) for a 1V input.
I really need to raise the input gain so I can attenuate the output of my Phasure NOS1 more to lower the DC offset and keep the NCores from going into protect without adding coupling caps.
Thanks for anyone's help,
Todd
Old 25th October 2012, 08:35 PM   #5270
Please excuse the obvious error of referring to resistance in microfarads as opposed to ohms and kilo ohms.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
