Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Class D Switching Power Amplifiers and Power D/A conversion |
#5101 | |
Banned
#5102 |
#5103 | |
#5104 |
Banned
Ya seems that way. It would be nice if I could adjust it at home. But on the other hand it might be a good idea to run that voltage regulator anyways. Unless it has any detrimental effects on the sound quality. I read some stories about other audiophiles using the APC regulator with their delicate tube gear with very positive results.
#5105 | |
Not sure what is the prescribed way to run cables carrying 600mV @450kHz so they don't radiate. Tonearm, which by design has a piece of unscreened, unshielded signal carrying wire is about a meter away. |
#5106 | ||
#5107 |
#5108 | |
Thanks. All good advice but not really applicable. Staying away from anything class D seems the easier option at present. |
#5109 |
#5110 | |
![]() Quote:
Certainly, I would expect tonearm wiring to be twisted. And I would pay special attention to the wires carrying the signal from the 'table to the phono pre as well, making sure that they are high quality, as short as possible, and properly shielded. I do not design phono pre-amps, but considering the high gain needed, would it not be prudent for them to be designed with an RF filter at the input? Perhaps this is one reason why so many who use low output MC cartridges prefer the sound of a step transformer as the first gain stage for vinyl playback, as the transformer itself should be an effective filter against high frequencies. I often wonder why people do not always take full advantage of the fact that phono cartridges output balanced signals; a fully balanced phono pre seems to make perfect sense to me, this approach, coupled with a transformer input, ought to be able to reject any noise pickup at all. |
Thread | Thread Starter | Forum | Replies | Last Post |
Hypex Ncore vs. NAKSA | AlliumPorrum | Class D | 1 | 26th May 2015 06:36 PM |
Problem with Hypex Ncore | Koifarm | Class D | 29 | 13th October 2014 06:32 AM |
Any news on hypex ncore 2.0? | JZatopa | Class D | 1 | 13th August 2013 10:30 AM |
Hypex UcD700 vs NCore | Earbound | Class D | 25 | 15th March 2013 04:10 PM |
Building a Hypex Ncore... | Jabbejokker | Class D | 0 | 7th March 2013 09:08 PM |
New To Site? | Need Help? |
